Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF
Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Antennas
Notices
CB Antennas
Mobile, Base, or other citizens band services antennas.
Reply
  #11 (permalink)
Old 11-08-2008, 05:51 PM
Senior Member
W5LZ is an unknown quantity at this point
Default
Coiling coax does make for an RF choke. But that's not bad, it doesn't affect the signal -inside- the coax, it only 'chokes' RF on the outside of the coax which you don't want anyway.
  #12 (permalink)
Old 11-08-2008, 09:02 PM
Senior Member
C W Morse is on a distinguished road
Default
Quote:
Originally Posted by madvillebirdman View Post
I have always heard that rolling up excess coax neatly causes an "RF" choke on the signal. I have always zig-zagged excess coax rather than winding it.
Good Luck. Check my post on "No Ground Antennas"
WHY would someone coil up "excess" coax? Cut the cable to the correct length to reach, TUNE the Gosh-darned antenna to resonance and for-GET about all this coax nonsense!!! If we are using coax to "tune" the antenna, then we don't NEED the antenna at ALL!!! Coiling up coax is another of these myths that become radio "gospel". We DO need the antenna, however, because it DOES more efficiently RADIATE the signal out into the air.
It is difficult to explain WHY we are having this problem on a forum. It involves several things that are difficult to explain. For a number of reasons, the antenna is not matching and it usually involves something called impedance. It can be caused by 1) insufficient ground , 2) improper mounting, 3) the antenna itself too short or long (NOT the coax). Is the antenna too CLOSE to the body of the vehicle? Is the body PLASTIC? Has the antenna itself been broken in some way (whacked by an overhead)?
If the antenna itself is OK, the mount is correct, the location is good and the system STILL will not "tune", then there are several solutions. I would highly recommend finding someone with an MFJ Antenna Analyzer that will read SWR and IMPEDANCE. By attempting to set the SWR while observing the IMPEDANCE, you will get an picture of what issues are present. If the antenna won't come into resonance and/or the meter won't read 50 OHMS, then you'll have a clue as to what's going on. Sometimes you can wind a small coil or use a small resistor(just a few experimental turns will do) and put it in series-series parallel at the feedpoint of the antenna. This MAY provide the correct impedance and present an acceptable SWR.
I know this is a complicated solution to what SHOULD be a simple problem. Normally, at 27 MHZ, such measures are not necessary. But, again, not knowing exactly HOW the system is installed.................................
Good luck with it.
CWM
  #13 (permalink)
Old 11-09-2008, 08:25 AM
mackmobile43's Avatar
Supporting Member
mackmobile43 is on a distinguished road
Default
Good luck with it.
CWM
Is'nt that what wind the coax in a coil does.lol leave to theory to complicate the most basic of CB lore.
  #14 (permalink)
Old 11-09-2008, 12:44 PM
Senior Member
Default
No. We are confusing a RADIATING coil with a device at the FEEDPOINT of the antenna that is used to transform a random impedance to 50 ohms. This device can be a little coil, a capacitor---even a resistor---- OR a toroid that is installed from the base of the radiating element (bottom) and taken to nearby ground. I don't want to get into a complex explanation of antenna theory, but what we are getting into is the mechanics of impedance. First of all, remember: RF ground is NOT necessarily DC ground. It CAN be, but often is not. That's where we must "fashion" a potential to ground that results in a 50 ohm path from the antenna to ground. I know, it doesn't make a whole lot of sense to those who may be new. This is where an antenna analyzer comes in VERY handy. Usually, at 27 MHZ, this is not necessary, the general rule being that the higher in frequency we go, the less we have to monkey with feedpoint impedance. This gets into the various values of resistance (feedpoint, radiation, and coil [if any] ) that are present in an antenna system. I don't have time to do that right now. After all, we have gotten off topic a bit and it won't help the fellow with his issue.
A coil that is IN the antenna itself is there for ONE purpose. It does NOT make your signal BIGGER or BETTER. It is there because the antenna is too LONG, & it has to be shorter due to physical limitations or height restrictions. In the case of lower HF frequencies (below 27 MHZ), some mobile antennas would have to be 60 feet long!!!! We can't have that!
CWM
  #15 (permalink)
Old 11-17-2008, 12:24 PM
dodgeman's Avatar
Junior Member
dodgeman is on a distinguished road
Default
where is the ant. mounted? is this on a big truck or a pick up? if it's on a pickup the ant. needs to be mounted so that 2/3 of the ant. is above the cab. otherwise you can get a lot of reflection and i believe you will have high swr's.
__________________
just a countryboy from wisconsin
mobil rig:
cobra 29 peaked and tuned and a 2sc1969 final, astatic 636 mic, 102" whip.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin®
Search Engine Optimization by vBSEO 3.2.0
Worldwide Radio Forum
