Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Using a small satellite dish as an 11 meter antenna
Like Tree26Likes
Reply
  #1
Old 01-02-2009, 06:39 PM
King Mudduck's Avatar
FEAR THE DUCK!
King Mudduck is an unknown quantity at this point
Default Using a small satellite dish as an 11 meter antenna
I have been playing around with this thing to today and i actually got it to work. What i did was drill out the center of a direct TV dish and mounted a 4 foot fire stick antenna there. I have it up about 10 feet right now as i am still working the bugs out but after figureing out the ground for this antenna i have the SWR down to 1.2. It's seems to receive and transmit very well and it is very directional with great rejection which is what i wanted from the start of this little project. The only reason i tried this was out of boredom but i was wondering if any of you have tried something like this.
The reason i posted this here was because most hams like to experiment and i thought that some of you may have tried this in the past.
__________________
Government = Massive spending, Higher taxes and Shredding the Constitution!
When will enough be enough?
  #2
Old 01-02-2009, 07:03 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
It's an interesting idea. But, how is the SWR? The dish doesn't exactly provide a tuned ground plane for it. Maybe if the dish was bigger? Th next thing you would have to do is put it on a antenna rotor after you work out the bugs...
__________________
BASE: Kenwood TS-2000 w/Alpha Delta DX-CC, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
"...2 WR-011..."
  #3
Old 01-02-2009, 07:16 PM
Sonwatcher's Avatar
Senior Member
Sonwatcher is on a distinguished road
Default
The answer was in the first post. Looks like he did pretty well !
KingCobra_CDX882 likes this.
__________________
http://www.haminfobar.co.uk
CDX-897
OT-897
WR-1897
AK-1897
RT-897
  #4
Old 01-02-2009, 07:54 PM
555 555 is offline
Senior Member
555 is on a distinguished road
Default
i did a 10k 27 inch shaft on one of the old stye metal satilite dishes
what 8 or 9 foot across
the dish is on a 14 foot pole to clear the back part of the house
undid the motor and hardware
had the dish looking straight up
mounted the antenna dead center of the dish
swr are flat
talks as recieves pretty good
nothing big and bad with spactacular numbers but it worked
__________________
Due To Price Increase On Ammo No Warning Shot will be fired. Sorry But Times Are Hard In Texas I apologize for any inconvience.
  #5
Old 01-02-2009, 08:11 PM
Sonwatcher's Avatar
Senior Member
Default
CDX-4540 and I pondered using a dish but couldn't figure out how it would work. Never gave a thought to mounting an antenna in the center .
__________________
CDX-897
OT-897
WR-1897
AK-1897
RT-897
  #6
Old 01-02-2009, 08:17 PM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt is on a distinguished road
Default
All the dish is doing is providing a groundplane and nothing more. You will not see any gain nor directivity with it. Any directivity seen is a result of a freak null in the pattern. A dish antenna is simply far too small to work on 11m. in fact a six foot dish is too small for even 2m.
Gain of a parabolic antenna
__________________
  #7
Old 01-02-2009, 09:01 PM
Sonwatcher's Avatar
Senior Member
Default
Garth, that was why we figured it wouldn't work. But I guess we could have made use of it with a hamstick attached .
__________________
CDX-897
OT-897
WR-1897
AK-1897
RT-897
  #8
Old 01-03-2009, 03:19 AM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
You might be surprised at what can be 'made' to 'work'. Doesn't say anything about how well it works, or what peculiar characteristics it may have, just that it 'works', sort of. Wanna try different things? Why not! The 'biggy' with that experimenting is that something usually gets torn up, one way or another. If you can't afford to loose it, don't use it. Sort of... Yeah, but it worked!
Reply
Bookmarks
Tags
antenna engineering, experimental antenna, home made antenna, loop antenna, magnetic loop antenna
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/cb-antennas/31793-using-small-satellite-dish-11-meter-antenna.html
Posted By For Type Date Hits
Using a small satellite dish as an 11 meter antenna - Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF This thread Refback 01-02-2009 07:45 PM 1
Powered by vBulletin®
