Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Homemade Antenna and Radio theory.
Reply
  #31
Old 03-12-2009, 12:37 PM
Junior Member
LumpySnake is on a distinguished road
Default
Quote:
Originally Posted by Mongoose View Post
I made a dipole antenna. Formula for this is- 468/Frequency.
Example 468/27.205=17.2 feet. I cut the #14 wire in half then stipped end of wire and connected one piece to the center lead of rg58 coax and the other to the shield sie of the coax. My center lead is HORIZONTAL (attached to the ceiling) and the shield is Vertical and I get a 1.2:1 match. Keep in mind that this in my basement because I live in a Condo, no antennas allowed outside. I can get out around 4 to 5 miles running a Galaxy DX959 and D104 M6B Mic powered by a Pyramid 12 amp power supply. What more can you ask for.
I got a 959 in my truck. Good little radio. Sounds great and gets out far.
Worldwide Radio Forum
  #32
Old 03-15-2009, 09:34 AM
DoctorMaster is on a distinguished road
Default
Always tune the antenna for lowest SWR. The better the match, the happier the transmitter/amplifier. I suspece you could have a component in your antenna that isn't handling the extra power well, or have a grond issue.
  #33
Old 03-20-2009, 04:14 PM
Senior Member
formulamojo is an unknown quantity at this point
Default
Put some water in that bowl...
Dog is probably thirsty and would most likely appreciate it...
__________________
MoJo
www.mojoenterprises.us
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/cb-antennas/32831-homemade-antenna-radio-theory.html
Posted By For Type Date Hits
Homemade CB Antenna This thread Refback 04-28-2009 09:46 AM 1
Homemade vertical cb antenna This thread Refback 04-23-2009 02:51 PM 62
Homemade cb antenna This thread Refback 03-19-2009 10:15 PM 22
Everything about homemade uhf antenna - Yahoo! Glue This thread Refback 03-03-2009 04:54 PM 2
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.1
