Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Old Hash, New Flavor? .55 or .64?
Reply
  #1
Old 03-09-2009, 05:37 PM
Senior Member
CDX-007 is on a distinguished road
Default Old Hash, New Flavor? .55 or .64?
I was just reading an old post that I can't believe I never found before today.
The penetrator
Unfortunately it is now closed, but DaveGrantSr made a point I wanted to address, hopefully without so much perceived hostility.
He wrote,
Quote:
"'The GODS blessed it and now we have the I-10K.'. another member of the 'church of steve & jay'. my $70 maco v5/8 is every bit the performer. nobody EVER heard me sound different on an i10k vs my v5/8, nor did i EVER hear anything on my i10k that i couldn't hear on my maco. all the reasons steve said that i had a problem, eddie wolf laughed at. he told me if my maco works, don't even waste the money on HIS antenna. THANK the RADIO gods for E BAY!!!! a used i10k sold for MORE then NEW! who woulda thunk it "
...and I just wanted to answer that with:
Dave, you're correct.
and,
Dave, You're incorrect.
IF you have one of the earliest Maco V5/8 you are correct, you shouldn't see any noticable difference between them.
I was informed by an Amateur friend of mine that when Maco acquired Wilson they were allowed to sell the old Wilson Alpha V-5/8 until out of stock, after which they had to make them shorter, legal CB antennas 20' or under.
The old Wilson/Macos were ~23' and were a true .64. I had one and it performed neck-n-neck with the Avanti Sigma5/8 and the Hy-gain Penetrator. I would've kept it but I had issues with the short-nippled aluminum radial hub, the Penetrator's radial mounting design appeared much stronger.
But,
If you have a newer, 19.7' Maco, you're incorrect. I have tested one against my Penetrator and saw no less than 1 S-unit loss to local stations within 5-10 miles. (While having the Penetrator down for a couple of weeks for cleaning and polishing, and testing a friend's new MacoV5/8 on the same mast, coax, radio, etc.)
If you have an old, original Wilson/Maco .64 then you have a terrific antenna and the only net gain I believe you'll see is in power handling should you replace it with an I-10K. However, if you have a newer, paper-weight 19.7' version MacoV5/8 you'll see a noticeable improvement in performance, unless you have no meter and only talk to people really nearby.
I hope to be purchasing a good used I-10K from a local who is taking it down to place a Beam on the tower, so if that goes thru I'll post the results of my many meticulous tests comparing the Penetrator to the I-10K.
I expect to see nothing but negligible differences, but am keeping an open mind. I'm always up for improving my station performance.
The I-10K IS the Penetrator of the 21st Century, and can handle substantially more power, but I doubt the claims that it otherwise outperformed the Penetrator, unless the Penetrator in question, and/or the coax hooked to it was loaded with oxidation from years of use.
I kinda hope I'm pleasantly surprised and end up admitting myself to "Jay's church of I-10k" - we'll see.
73zzzzz
__________________
______________________________________
__________________________________________________ ___________
__________________________________________________ ______________________________________
hy-gain Penetrator 500 .64 and A1 Antennas Interceptor I-10K .625 @ 40' & ½ Wave Apart
-->> Neck & Neck Performance. ...and that's "My Daddy's Penetrator 500"
Worldwide Radio Forum
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.1
