Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
maco 107 is up
Reply
  #1
Old 04-13-2009, 02:01 PM
GunSlinger338 is on a distinguished road
Default maco 107 is up
got it up this weekend
andrews 5/8 from the 10k gamma....... just in case
Worldwide Radio Forum
  #2
Old 04-13-2009, 02:54 PM
Rob KI6USW's Avatar
Senior Member
Rob KI6USW is on a distinguished road
Default
Wow...Some SERIOUS skip talkin there!
How tall is the tower base to the feed point?
Are you going to keep it horizontally polarized?
Or are you going to be able to mechanically shift between the two?
Are locals still hearing you well - even though it is horizontally polarized?
Give us some numbers and some DX reports - please!
__________________
What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9...no linear power
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770...no linear power
  #3
Old 04-13-2009, 03:26 PM
Bionic Chicken's Avatar
Senior Member
Bionic Chicken is an unknown quantity at this point
Default
I'd rate the M107 as the best antenna that Maco made. I know the advertised specs of the 108 are higher but after having had both the 7 element is a better performer hands down. The bandwidth on the 8 was wider than the 7 but that didn't bother me any. 4500 watt key with 12 watts reflected was good enough.
I am sure you will enjoy the antenna and the T2X is the way to go with it!!
BC
__________________
BC
  #4
Old 04-13-2009, 07:33 PM
Highlander_821's Avatar
Amour d'Ecosse
Highlander_821 is on a distinguished road
Default
Wow, that's great!
__________________
Highlander, NA-821 on 11 Meters.
N9RZF, David on Ham Bands.
Yaesu FT-847, Galaxy DX-2517, President Lincoln, Cobra 150 GTL, Uniden Grant LT.
  #5
Old 04-14-2009, 08:25 AM
Default
i have 7-8 feet from the boom to the top of the mast pipe and want to put a ground plane up there...
the question is.....
Will the radials of a ground plane antenna like a Maco 5/8 affect the beam more so than a ground plane antenna like an Imaxx with out the radials ????
I expect to have some interference either way... but could it be minimized by using an Omni without the ground plane kit ???
  #6
Old 04-14-2009, 11:31 AM
kswitchdr is on a distinguished road
Default
I have ran a Shakespere big stick on top of my Super Laser 500 flatside for years now. It is the same design as the Antron. Never really had any problems with this setup. Not sure about running the Maco though.
  #7
Old 04-14-2009, 05:49 PM
Senior Member
hotrod is on a distinguished road
Default
wow what a monster of an antenna
how tall is your tower
how ya keeping that big beam up up?guy wires?
__________________
magnum delta force
magnum omega force
uniden grant
cobra 2000gtl
sirio z180
skythumper65dx
  #8
Old 04-14-2009, 06:08 PM
Default
no guy wires..........self standing crank up with a 4'x4'x4' concrete and rebar block at its base
Its right at 45 foot to the boom
it can be lowered below the roof line .. if it get bad
  #9
Old 04-15-2009, 07:58 AM
Drifter's Avatar
Senior Member
Location: Under a coconut tree in the Carribbean sipping on white rum and coke!!!
Drifter is on a distinguished road
Default
Nice... I have a similar looking 60' with mast self supported crank up tower but I have 6 element quad on it though. Can yours crank to fold over?I love that feature on mine. I don't have to climb the thing to work on my antenna.
__________________
Yaesu 101E
Signal Engineering lightning 6 quad Antenna on a 60FT crank up tower.
  #10
Old 04-15-2009, 10:04 AM
Senior Member
linearone is an unknown quantity at this point
Default
oh man, soon you will need that base power supply lol
__________________
Bomb Diggity!
_____________________________________
Quote Bob85: "peoples' personal non factual opinions mean nothing to me period, BS is 10 cents a gallon anywhere you look for it"
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
