I think you've probably hit on the probable cause, maybe. I seriously doubt if you'll tell any difference in performance with that slight of an SWR fluctuation. BUT, the problem is that it might get worse. Taking it down, giving a good 'going-over' and fixing any obvious thingys is a good idea. It might also be something internally wrong, so if tightening things up doesn't correct the problem, I think I'd be looking at a new antenna, maybe.
- 'Doc |
