Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Homemade CB antenna radials question
Reply
  #9
Old 08-28-2009, 03:33 PM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
That would sort of complicate getting the radials outside of the pipe, but should work. Or, how about just making a 'sleeve' dipole instead of that groundplane and putting the whole thing inside the PVC? A 'sleeve' dipole benefits from having a choke at the bottom of it.
  #10
Old 08-28-2009, 04:08 PM
Junior Member
Nationalpatriot is on a distinguished road
Default
How would I go about building that? (my hardware store closes in 2 hours about, need to know so I can run over there)
  #11
Old 08-28-2009, 06:33 PM
Default
A 'sleeve' dipole is about as simple as it gets. Remove the outer insulation from about 9 feet of coax. Sort of push the braid down and over it's self (turn it inside out) until there's about 9 feet of it down the coax from where the center conductor and insulation extends above it. So you end up with the coax feed line running up through one 'side' of the dipole to the center, where the center conductor and insulation make the other half of that dipole. Sort of like;
---////-======o................ (Great graphics, huh?)
That "---" is the coax, the "////" is the coaxial choke, the "o" the center of the dipole, and the "............" the center conductor.
That 'about 9 feet long' on each side of center is too long, but allows some 'extra' for making a loop to hang the thing from, and you trim the rest to the right length like normal. Keep both sides the same length. A good thing to do is seal that place where the braid turns back from the center conductor, don't want water getting in there. figure about 18 feet of coax as the minimum length required. A PL-259 on the end of it, a double female and then the feed line to where ever it's going. That doesn't include the choke, just wind it in the feed line.
(Just hang the flag from the PVC containing the antenna.)
  #12
Old 08-28-2009, 09:22 PM
Junior Member
Default
Done. I'll grab some pictures for ya'll tomorrow. It seems my camera decided to NOT work at the most unwelcomed time...
  #13
Old 08-29-2009, 03:17 PM
BOOTY MONSTER's Avatar
Supporting Member
BOOTY MONSTER is on a distinguished road
Default
i think this is what doc is talking about .
http://www.iw5edi.com/ham-radio/?the...oka-antenna,18
__________________
i used to think people were attracted to me because of my charm and personality
but my doctor just told me it's because i'm so fat that i have my own gravitational pull
  #14
Old 08-29-2009, 05:04 PM
Default
Booty',
I have to admit that that 'vertical bazooka' is made like a 'sleeve' dipole, but I'm sure you can see a difference or two.
Never heard of it being called a 'vertical bazooka' before, and since it isn't fed the same way a bazooka antenna is fed, I wonder why? How about an 'OCF Vertical Bazooka', since the two 'parts' to the thing aren't the same length, and it's certainly not a 'balanced' antenna anymore. I think it would still benefit from putting a choke at the bottom of it.
  #15
Old 08-29-2009, 05:22 PM
Supporting Member
Default
my bad , thanks for the correction doc.
__________________
  #16
Old 08-29-2009, 09:09 PM
Junior Member
Default
Alright here we go, (had to use the camera phone)
$15 bucks at my local hardware store, Gonna paint it in brown/green camo. each of the 4 braces are 5 foot long about, the first length of 1" verticle is 5 feet, next length of 3/4" is 2 feet and the last length of 1/2" is 2 foot also. The junction is just a 1 inch 4-way piece of PVC with a small piece of 1" to a T with the vert. aiming up (in which the mast inserts upwards into). At the top of the 1/2" is a end cap with hole drilled in it for the coax center to go through. This thing was handling 16 MPH winds easily today, also, the erm..."flag" sit perfect height on it.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/cb-antennas/35854-homemade-cb-antenna-radials-question.html
Posted By For Type Date Hits
Homemade cb antenna you build This thread Refback 11-02-2009 04:48 PM 74
Homemade vertical cb antenna This thread Refback 10-31-2009 01:30 PM 32
Homemade cb antenna This thread Refback 09-19-2009 07:22 AM 35
Home made dipole cb antenna This thread Refback 09-10-2009 06:10 AM 78
Powered by vBulletin®
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
