considering an M400 starduster. whats the deal?  | |
09-07-2009, 07:07 PM
|  | Senior Member | | Join Date: Mar 2006
| | W5LZ, (Led Zepplin?)
the radials are not insulated from the lower portion of the hub.
the only thing insulated from the "ground" portion of this antenna is the vertical radiator.
both the radials, and the mounting pole are connected to the shield of the coax.
hope that helps clear things up.
__________________ "Man shall never reach the moon, for such a quantity of gunpowder would be needed as to gravely injure the crew."
~ Children's Encyclopedia, 1926 |
09-07-2009, 11:30 PM
| | Supporting Member | | Join Date: Apr 2005 Location: Oklahoma
| | loosecannon,
Going by the assembly instruction posted, the radials are insulated from that pole, there are insulators on the radials between the support pieces holding the radials away from the pole (both ends). That makes me tend to think that the 'large hub' is also insulated from the pole, otherwise, why bother with the other insulators??
(W5LZ = Lost Zipper) |
09-08-2009, 09:29 AM
| | BANNED | | Join Date: Apr 2005 Location: non-cartesian cyberspace
| | "....the 'large hub' is also insulated from the pole"
it isn't. the hub, the radials and the mast are all at the same current potential.
09-08-2009, 02:31 PM
| | doc,
the only reason those radials are attached to the mast at all is for wind support.
im not sure how else to say it.
they are radials. they are connected to the shield of the coax, and they extend down from there.
i am not guessing about this. thats the way it is.
09-08-2009, 03:05 PM
| | Senior Member | | Join Date: Oct 2006
| | Hey bro. hereʻs part of a starduster just the radiator(main ant) and 1 ground radial laying on the roof and I still got below 1.5:1 SWR.
__________________ Mobile:
Prez Grant Export
Black Widow 350V
9" Predator 10K
RS SWR/Watt Meter
Base:
Soon to be "COBRA 2000"
Pyramid 25 Amp P.S.
partly assembeled Starduster/  works well too, 1.3:1 SWR.... |
09-08-2009, 03:23 PM
|  | Old Grandpa | | Join Date: Oct 2005 Location: Houston
| | Quote:
Originally Posted by loosecannon yes marconi, LOL i meant 1/2 wave vertical dipole. you said that the starduster is fed a bit off center? are you saying this because the top radiator is a bit shorter than 108"? | My reasons for my off center claim has to do with the diameter of the SD's tapered elements which likely average 2-3 times larger than that of a 102"-108" SS whip or a similar size wire. Having thicker diameter elements I would think the SD'r elements should be considerably shorter than 107" in order to maintain resonance. The rules of resonance have to apply and if we substitute SS whips we would have an overall lengthof 204"-216" and that tells me that the SD'r would either be way too long or it has to be loaded off center a bit with the radials being longer than the stinger. The physicals of a SD'r follow pretty close to the 5%> rule that applies to ground plane elements and is often mention in discussions regarding radials. Maybe my saying "off center loaded" is not a good description of what is really going on, but that is what I was thinking. Quote:
Originally Posted by loosecannon looking at the owners manual, i get the finished length of the top radiator at about 101" give or take. the radials, however, are 107" long, which says to me that this antenna is not fed off-center, but that the small radials on the top element form a capacity hat, thereby reducing the main radiators length. | The stinger of my original SD'r is 99" made up of three tapered elements, 1/2"X51.25", 3/8"X20", 1/4"X27.75". On-the-other-hand my knock-off SD'r is 98" made up of two tapered elements, 1/2"X51", 3/8"X47". Assuming both antennas are designed for the middle of CB, which is likely, this one inch difference is totally ascribable to the diameter differences and that diameter difference is probably small as a percentage. So if we consider the differences between a whip and these elements we might expect to see a sizable difference in length while the GP elements fall near the top of the 102"-108" standard of length for the mobile whip. Quote:
Originally Posted by loosecannon lou franklin says that this also lowers the take-off angle in his book "understanding and repairing CB radios". | Quote:
Originally Posted by loosecannon im interested to hear your thoughts on this. | I don't know what Lou Franklin knows, but if he thinks and you believe that the these small projecting radials have an effect on TOA, then that is fine with me. I can't prove or test TOA and I don't consider such information very important in the performance of the mono-frequency vertical antennas we use in CB. I hear references to the term in CB chatter, but too often it is just BS on the subject, a subject that is probably only derived thru a very complicated understanding and application of physics. Frankly I think the real issue of TOA is controlled mostly by the conditions of the soil below the antenna and in the far field. And to a lessor degree controlled by the height of the antenna. For me TOA is just another word used by guys that try to impress and come across with categorical claims about what they know about antennas. Quote:
Originally Posted by loosecannon as for the owners manual, here is a | Quote:
Originally Posted by loosecannon | Thanks for the link. That is an original SD'r spec sheet. I think it is just common sense about the 10' foot mast if the fact is the coax exiting the antenna inside is shielded from the inductive RF in the lower half of the antenna, which IMO is probably a good idea for some improved performance. Quote:
Originally Posted by loosecannon about the choke balun; we know that when erecting a vertical dipole, you shouldnt run the coax down the mast parallel with the "ground" element of the dipole. when this is done, currents are induced onto the shield of the coax. it should be run out perpendicular (90*) from the antenna elements. meaning that the coax will be horizontal to the ground for at least a quarter wavelength. | Quote:
Originally Posted by loosecannon maybe this is why A/S wants the coax to be inside the tube. hmmmm... i am currently reading up on vertical dipoles and sleeve baluns. hope to know more by tomorrow. thanks for your interest! LC | LC, you make a good point, but your last statement is arguable as well, considering that just about every dual polarity yagi multi-element antenna pretty much violates the rule you site, plus you hear very little discussion about this issue concerning beams---as though it is not even a problem. Like I said before, "...we are just very lucky that Mother Nature does not require us to be perfect in what we do concerning our radios and antennas." |
09-08-2009, 05:02 PM
| | Junior Member | | Join Date: Jul 2009 Location: 60 Mi S. Houston,Texas
| | considering an M400 starduster. whats the deal? Quote:
(W5LZ = Lost Zipper) | As others have noted the radials are not insulated at the hub. They are supported lower down the radial away from the mast by insulated spacers or rods; for mechanical and rf stability. The radials are resonant and if the spacing away from the mast changes so does the tuning. The starduster when properly tuned has the same amount of current flowing in the radiator as the radials. As for the name you choose to use to describe the Starduster that's open : 2 1/4 wave elements same as the old 1/4 droopy Groundplane,the original coaxial vertical and the newer coaxial bazooka
designs. I believe that the Starduster was designed with the radials at the angle they are was an attempt to raise the impedance of the antenna closer to 50 ohms. The radials also act as a sleeve with the large diameter at the bottom of the radials producing a high impedance point. The earlier vertical coaxial dipole designs suffered from bad feedline radiation due to the sleeve being pipe or alum of 2 inches in dia. Reason being the ratio of the feedline dia to the sleeve was not great enough to produce the high impedance needed at the bottom of the sleeve for the antenna to operate correctly.
The only improvement i can think of would be to increase the number of radials on the Starduster to simulate a complete sleeve. Have any of you
seen the ISOPOLE brand of 2m/440 antennas same theory with more decoupling.
I once built a coaxial vertical for 10 meter FMand had to use 4" alu for the sleeve to reach acceptable decoupling. It is really great to see all the discussion on antennas.
73 RCB |
09-08-2009, 05:42 PM
| | marconi, you are right. i hadnt considered the way coax is run to a beam antenna.
so, the way i see it now, is that this antenna is a 1/4 wave groundplane antenna with a sleeve over the coax to help reduce coax radiation.
thanks to all who replied.
good thread.
09-09-2009, 10:30 PM
| | well, im really glad i learned everything from this thread that i did, but its not going to matter for me as i just made a deal with someone to buy their "top one" astroplane copy.
i cant wait to get it and put it up as i was very happy with my last one.
this is the antenna that i really wanted for my birthday anyway. LOL
09-10-2009, 12:12 AM
| | Happy Bday LC. Them Astro are top choice too, hope to catch you on the band!!!
1-5
Prez Grant Export
Black Widow 350V
9" Predator 10K
RS SWR/Watt Meter
Base:
Pyramid 25 Amp P.S.
partly assembeled Starduster/  works well too, 1.3:1 SWR.... |  | | | Thread Tools | | | | Display Modes | Linear Mode |
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -7. The time now is 06:08 PM. |
