Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Recommend Ground Plane Kit For Imax 2000?
Closed Thread
LinkBack (1) Thread Tools Display Modes
  1 links from elsewhere to this Post. Click to view. #1
Old 09-04-2009, 12:31 PM
Wire Weasel's Avatar
Honkus Maximus
Wire Weasel is an unknown quantity at this point
Default Recommend Ground Plane Kit For Imax 2000?
Looked a bit for other existing threads and didn't see one.
Anyone use an Imax without the GPKit and then add it later? Significant improvement?
TNX
__________________
Supplying All Your Wire and Weasel Needs Since 1869 * All Orders Come With A Free Pack Of Vazomyne For Sustained Performance
Worldwide Radio Forum
  #2
Old 09-04-2009, 01:51 PM
Rob KI6USW's Avatar
Senior Member
Rob KI6USW is on a distinguished road
Default
Nah, I never got the GPK for my IMAX.
Seems to work extremely well with either DX or local - as is.
I don't know if spending an extra $50 will be worth the 2db gain.
If you use it, I'll consider your response if I am going to buy one.
BTW - Would the A99 GPK work on the IMAX? I know they attach differently; but can they be adapted? I have a friend of mine that has one - that wants to get rid of it...
__________________
What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770.
"...The 444 in San Jose CA; the Central Gold Coast..."
  #3
Old 09-04-2009, 02:08 PM
dudmuck's Avatar
Senior Member
dudmuck is an unknown quantity at this point
Default
Depends on what you're trying to improve. If your problem is TVI or the like, then the GPK is a big plus. Either that or an ugly balun coax choke.
The antenna needs some kind of counter-poise. It'll use whatever metal is connected to it, coax shield or mast.
Even if you dont put on the GPK, you should at least consider the ugly balun choke especially if you run Big Watts. Only to prevent RF on the outside of coax, which causes TVI.
__________________
"Y'all mind hanging back? You're jamming my frequencies" -- Tangina in Poltergeist
  #4
Old 09-04-2009, 03:43 PM
BOOTY MONSTER's Avatar
Senior Member
BOOTY MONSTER is on a distinguished road
Default
you could make one out of speaker wire and pvc pipe and attach it to the 2000s mounting plate . if going with store bought i like the looks of the 3 or 4 sloped starduster type . much better looking than the saw horse looking one made for the 2000 . but looks arnt everything . insulating the antenna from its mast and earth ground and using a coax choke seems to be the best way to install them .
Isolating vertical endfed antennas from their support structures
__________________
  #5
Old 09-04-2009, 05:40 PM
Honkus Maximus
Default
Thanks everyone. This has led to some excellent info. Thanks to the Botty Meister for the great linky here on the site. WWDX comes through again.
I've sprung for the GPK and will isolate the antenna system from the metal mast.
Have recorded the normal signals from about 10 locals all around me. Will compare the results. Also will watch the TVI I'm getting from another current thread on other forum here. Antenna base will remain at same height as now.
__________________
  #6
Old 09-04-2009, 08:30 PM
Senior Member
Default
thanks for making note of how its doing for befor and after results . i look forward to them .
__________________
  #7
Old 09-04-2009, 08:55 PM
Honkus Maximus
Default
While I'm waiting for the new stick, I'm going to yank the existing vertical down tomorrow morning and isolate it from the mast.. Then put 'er back up and see if that cleans up my TVI
I'm actually gonna be pretty pissed if this works..ha ha. I've been putting up with alot of crap a long time just to see it all go away by something as simple as this. Dammit boy!
__________________
  #8
Old 09-04-2009, 10:11 PM
Rob KI6USW's Avatar
Senior Member
Default
What kind of material are you going to use to isolate it from the mast?
A piece of rubber radiator hose?
Or - ???
__________________
What gear do I use?
  #9
Old 09-05-2009, 07:35 AM
Honkus Maximus
Default
I have tire inner tube rubber on hand. Will use several wraps. Off to do it now......
__________________
  #10
Old 09-05-2009, 08:57 AM
Senior Member
HiDef is an unknown quantity at this point
Default
Quote:
Black rubber is a very poor insulator for R.F.
Closed Thread
Bookmarks
Tags
292 radio shop, common mode current
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/cb-antennas/35992-recommend-ground-plane-kit-imax-2000-a.html
Posted By For Type Date Hits
imax 2000 | VIRGILIO Ricerca | Web This thread Refback 10-04-2009 10:23 AM 1
Powered by vBulletin®
