Hello Office 888:
You first sentance is hard to follow. What are 2 x 239 fittings???
The SWR will be high just laying on the ground. This is not a good SWR test.
Its a know fact that dipole antennas as most all antennas will change SWR when the heigth is changed.
The SWR will change with heigth, but if your not using a Balun the SWR can get crazy and not work to well. Some dipole antennas without a Blaun will seem to work, but all my experiences show the use of Current Balun is a good call.
The ARRL Antenna Book and Radio Handbook show how 1 to 1 Current Baluns are used and made.
Best 1:1 Balun 1.5 - 54MHz Dipoles & Yagis 5kw - #1115 Transmitting Baluns BALUN UNUN
The higher the dipole antenna the better.
Good Luck
Jay in the Mojave
Upate: Here is a great paper on the Balun, and its uses.
http://w2du.com/r2ch21.pdf
The Book Reflections II is well worth the Doe Ray Me.
Jay in the Mojave
Quote:
Originally Posted by office888 Decided to try to make my own 11m dipole.
Used an SO239 "Tee", and 2 x 239 fittings. I split 16ga lamp wire down the middle. Each leg is 103.25". I soldered one side to the center signal fitting, and the other to the outer ground fitting.
So then I went to check the SWR before I hung it up. I laid it out, and checked it with TWO different meters. SWR overall is high, almost 10:1.
Any ideas? Do I need a Balun?
-Richard- |
