Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
modified vector 4000
Reply
LinkBack (4) Thread Tools Display Modes
  #11
Old 11-03-2009, 04:32 AM
Senior Member
fnkycoldmedina is on a distinguished road
Default
looks great .if he starts making these and selling them i,ll have to get me one .hows the swr on it ?bandwidth?
Worldwide Radio Forum
  #12
Old 11-03-2009, 02:27 PM
Key Up City Radio
bigred222 is on a distinguished road
Default
he wont maybe he'll tell you how to make one yourself but i dont think you will ever see the shockwave vector 4000 at copper.com
__________________
Galaxy DX2547
Antron 99
Cobra 29xlr
Cobra 21Ltd Switch kit special
ADX-202
CDX-202
WWW.CBJUNK.COM Come here for fine CB Chatter
  #13
Old 11-03-2009, 04:43 PM
BOOTY MONSTER's Avatar
Senior Member
BOOTY MONSTER is on a distinguished road
Default
one could always homebrew a copy if they had the measurements ..... and confidence to try .
Aluminum Tubing Type 6063 - 6 ft.
mmmmmmmmmm..........................
might be time to start asking/learning about gamma matches . blame bob , shock and W5LZ , LOL
are there any other omni cb antennas besides the vector and its copies and the wolf .64 antenna that use a gamma match for tuning ? what's the benefits of one over the other ? any difference it tuning ability ? tx db gain ? noise floor ? ears ?
W5LZ if i paint it pink will it make the modulation louder ?
Wolf Radio.com CB, Ham, Pirate Radio Antennas [CB Antenna]
so a gamma is just a rod that can have its length adjusted going up and down the radiator vs. a coil or ring circuling below the bottom of the antenna and being taped for resonance ?
__________________
  #14
Old 11-03-2009, 06:18 PM
Senior Member
hotrod is on a distinguished road
Default
well im not a antenna designer by any means but i would
think a gamma tuning would have less loss than a coil and probaly the
same if not slightly better than a tuning ring.personally i like to see it
in 50 or higher mph winds.and 1 inch thick ice on it.up here in p.a
a strong antenna is a must.the I10k is outta my price range
__________________
magnum delta force
magnum omega force
uniden grant
cobra 2000gtl
sirio z180
skythumper65dx
  #15
Old 11-04-2009, 11:28 AM
Shockwave is on a distinguished road
Default
For those that were wondering what my measurements on this antenna are......Here you go. The vertical whip is 29 feet 7 and 1/4 inches long from the bottom of the connector bracket to the tip of the whip. The four radial arms are 81 and 1/2 inches long from end to end. The loop is 129 inches in circumference. The gamma is simply adjusted for lowest VSWR. Sorry I did not measure the gamma and I did use a home made Teflon gamma match with a weatherproof HN connector.
You may notice this last version of the antenna is more sturdy. I used the parts from two Vector 4000 antennas so that I could double up the lower sections and cut the flimsy top sections off. The four black plastic arms that hold the radials in place are also taken from two antennas. The ends were cut and then two pieces were screwed together with 4-40 hardware to make them longer.
The antenna was tuned on 11 meters and still provides under 2:1 VSWR on 10 meter SSB. The gain and bandwidth with the larger loop seems better to me and certainly exceeds what is possible with a 5/8 wave. The main advantage of the gamma match versus a coil with a tap is that a gamma allows you to tune out both capacitive reactance and inductive reactance. The coil only allows you to adjust the inductive component.
  #16
Old 11-05-2009, 03:58 AM
Marconi's Avatar
Old Grandpa
Marconi is on a distinguished road
Default
Hey Shockwave, I thought a gamma can only tune to a capacitive type load and thus the gamma has a smaller spectrum for use as compared to a series inductive type coil used for matching?
  #17
Old 11-05-2009, 08:56 AM
Default
Hello Marconi,
The gamma match is a variable capacitor that also forms a variable inductor. By sliding the gamma rod in or out of the gamma tube you are changing the capacitance. By sliding the gamma bracket up or down the driven element where it attaches to the gamma rod, you are changing the inductance.
One experiment I've conducted used a gamma match on a driven element and was able to tune the element for flat VSWR while adjusting the length of the driven element all the way from 1/2 wave to 5/4 wave. The gamma had much more tuning range then I originally expected and seemed to be able to tune almost any length radiator.
The one exception where the gamma could fail to give a match would be if the driven element were significantly shorter then what would be required for resonance. To add electrical length to the antenna we slide the gamma bracket more towards the grounded part of the driven element. At some point this stops looking like adding more radiator length to RF and starts to look like a short circuit.
Generally speaking when an antenna is too short to resonate, we add inductance to the matching network in order to cancel out capacitive reactance. When the antenna is too long, we add capacitance to cancel out inductive reactance. The gamma can do both however, it has limitations when the antenna is too short.
  #18
Old 11-07-2009, 04:45 PM
Marconi's Avatar
Old Grandpa
Default
Thanks for your remarks Shockwave. I re-read my post and I think I was confused in my argument and maybe got things backwards. I am trying to get back to posting, but I'm still recuperating from a recent 7 days in ICU flat on my back. I'm very weak and my thinking is not clear enough yet for detail discussions.
Right now I’m staying with my daughter until I get my strength back. I had a bout with Aluminum oxide inhalation poisoning that resulted in pneumonia. During the stress with my lungs being inflamed, my heart went A-Fib and my condition was all complicated with my diabetes as well.
A caution to everyone, be careful and work cleaning your aluminum antennas---in a well ventilated area only.
  #19
Old 11-15-2009, 06:09 AM
Senior Member
CDX-007 is on a distinguished road
Default
Giving this project a little thought, I believe I can use the ground hub of my other Penetrator base for holding the cone arms and make a Gamma match. What's the chance you could post the measurements of the Gamma?
Is the main radiator insulated from ground at the bottom or DC to ground & the radial arms?
  #20
Old 11-19-2009, 06:25 PM
Junior Member
supergonzo is on a distinguished road
Default
OK, so how does it perform? And against what and how did you measure?
__________________
6 element homemade cubical quad
Hygain Super Penetrator
Turner Ultra Kicker Base Antenna
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/cb-antennas/36412-modified-vector-4000-a.html
Posted By For Type Date Hits
GRUMPY'S OLDE TIME RADIO FORUM / The Best CB Radio Forum on the Net for Browning/Tram & Classic Tube Type Radio Information - Avanti Sigma IV (AV 174) This thread Refback 11-07-2009 09:58 AM 1
Avanti Sigma IV (AV 174) This thread Refback 10-31-2009 06:42 AM 8
GRUMPY'S OLDE TIME RADIO FORUM / The Best CB Radio Forum on the Net for Browning/Tram & Classic Tube Type Radio Information - Avanti Sigma IV (AV 174) This thread Refback 10-25-2009 08:56 AM 3
GRUMPY'S OLDE TIME RADIO FORUM / The Best CB Radio Forum on the Net for Browning/Tram & Classic Tube Type Radio Information - Search Results This thread Refback 10-25-2009 08:01 AM 1
Similar Threads
Retailers Breakin the Law? C2 FCC & ARRL Activity 170 10-18-2009 09:39 PM
Modified silver rod (Spiderplane) multimode200 CB Antennas 35 03-21-2009 08:30 PM
Modified CB Radio for AM Band Broadcaster loverboy Announcements & Open Forum 4 11-01-2008 09:56 AM
my modified quad mag mount BIONIC_TEXAN88 Station & Mobile Pics 5 12-12-2007 06:11 AM
Modified Trucker 5000 for Ham band fasteddy CB Antennas 1 09-20-2004 05:37 AM
Powered by vBulletin®
