Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
IMAX 2000 - Results w/GPK? Balun? Mast Isolation
Reply
  #1
Old 10-05-2009, 05:59 PM
cominatyalive's Avatar
It's only what you give.
cominatyalive is on a distinguished road
Default IMAX 2000 - Results w/GPK? Balun? Mast Isolation
Was reading the closed thread from Wire Weasel on the Imax 2000 antenna.
A lot of good info for sure as I just put one of these antennas up about a month and a half ago. As with everything else, I usually don't screw with something unless there are problems and I went ahead and installed my 2000 up on my house 59' total in the air without a Balun, GPK, or mast isolation.
Well, from the git go & currently, I have about 1.5 db worth of ground floor noise, and interference from what seems to be my power mains from the power company's main feed into my home and from my circuit box as well.
Today I removed my ground cable totally from my mast & unhooked my ground from my equipment. Still the noise. Like a 60Hz hum. I took the coax off the radio as well. It did not hum, but there was still a bit of static.
I installed a 20amp EMI filter in the circuit before the radio, still the noise. But I don't know if this filter is even doing anything. Still the noise.
Anyways, getting to the point here, I am about to go all out here and install a RF choke Balun using a 8" X 3 1/2" PVC pipe, a GPK kit, and better coax. I am going from a RG8X mini coax to a better quality of LMR-400. I am also going to use a two foot Delrin rod to isolate the mast.
I will be doing all of this in the next week or so as long as the weather permits here. I am posting here in hopes of providing my testimonial of evidence of improvement or not. We will see.
For anyone who cares to keep track of my efforts here & my documentation, please feel free. I have another current posting in the CB Radio forum ( Crackling 60Hz hum every third channel) I suppose I should have posted here from the start, But at the time, and currently, cannot yet provide a pin-point in the disturbing hum I have everyday through my Base Station. 1 DB worth of ground floor noise mixed with what seems to be a 60Hz hum from my house mains.
I have already tried many things to pin point this trouble. I will share all my results, (If any) with all. Here is the link to my main post in the other forum. Please feel free to add your two cents worth. And that is no joke.
Crackling 60hz hum three channels in a row, every 4th channel clear as a bell.
__________________
"What we've got here is a failure, to communicate! Some men you just can't reach. So you get what we had here last week, which is the way he wants it! well, he gets it! I don't like my Solarcon IMAX 2000 any more than you men". (and that's no joke!).
Worldwide Radio Forum
  #2
Old 10-05-2009, 07:52 PM
Rob KI6USW's Avatar
Senior Member
Rob KI6USW is on a distinguished road
Default
You have a lot less noise on your IMAX than I do - and I wouldn't trade this antenna for any other. You have the same problem with your setup that I do - I'm too close to the power lines. I live with it, and it is OK. Could be a lot worse; I have a friend that lives close by me that gets 20 S-units on noise!!! No Joke. If I have between 1 to 3 S-units of noise floor - it is a lot better that having 20 S-units!!!
Don't blame the antenna or yourself. What kind of power supply are you using? Or radio? Power supplies that have weak filter capacitors are going to leak 60 cycle hum. So - have you tried another power supply? Or a different radio - just to figure it out?
__________________
What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770.
"...The 444 in San Jose CA; the Central Gold Coast..."
  #3
Old 10-05-2009, 08:36 PM
Default
Hello Rob,
In regards to your noise, I suppose I should count my blessings. Yes, these antennas are really sensitive to picking up noise, but I believe there are ways around it.
Yes, I've tried everything, Even used a car battery to get around my AC power. Still the hum or buzz. I have a power supply, but only use it on my Cobra mobile.
I'm using a President, Zachary T. Base station unit. It has been restored & gone over, everything new or refurbished in it. It's really a great radio. But still the Noise.
I just sold my Cobra 139 base station & the noise was there also. It's even on my mobile when using the power supply or the car battery, makes no difference at all.
I shut off all my circuit breakers in my house except the one my CB is on. Still the hum. Nothing fazes this hum at all & I can't get rid of it.
I am starting to conclude it is the mains or a ground loop I am not aware of or my antenna picking up the power lines as you stated sounds more of what it is actually. But the power lines are not throwing out any frequencies.
I use a AM transistor radio to detect AC noise, works great. So far, the only noise that matches what I hear is the house mains noise.
Anyways, I'm hanging in there.
Keep me posted on your efforts as well. We need all the help we can get.
James
__________________
  #4
Old 10-05-2009, 09:18 PM
Rob KI6USW's Avatar
Senior Member
Default
If you are certain that the noise source are the power lines; then you can complain to the power company. You can! Remember; that this noise also affects wireless computer usage. The power companies are required to service poles that have either noisy transforners and/or insulators that give off excessive spurious RF. My friend that has the 20 S-units of noise has done this - and the power company is still in the process of making several repairs locally for these reasons.
The noise is something that I put up with. This antenna and radio setup I use -this year- has allowed me to talk all of the way to Alaska, Hawaii, and everything West of the Rocky Mtns. Even Mexico and Canada - w/o using linear power. I have no complaint with this antenna. It is often the enviorment that affects the usefulness of any antenna setup - Ham or CB...
Edit: Some people that I know have used handheld CB/walkie-talkies to get close to the loudest interference to find the source. Maybe someone you know has one. I used my car/CB radio and drove around my neighborhood to find the noisiest source. I didn't have to go far; it was much worse across the street from me. The transformer was the source of my RF noise!
__________________
What gear do I use?
  #5
Old 11-06-2009, 10:53 PM
Default
Installed the GPK kit a few days ago on my Imax 2000. To be honest, I can't really tell if there is a difference or not. The noise floor seems to be a bit lower on the db meter, around 1 db on the higher stations to 1.5 or more on the lower channels. 5, 6, etc. I'm still getting a hum in my radio from the mains, but it's less noticeable on the upper channels. 10 & on up through 40.
Worth the $50.00 dollars?, well, my Imax is 60' total height. I think it has helped a little. I have no results on transmitting yet.
I have other things to try yet. I have a home made RF balun choke & better coax to install soon and I'll let everyone know of my results. I still as of yet to isolate my antenna also from the mast, for what it's worth.
Every little bit of progress will make a difference in the big picture.
Good luck to you guys with your Imax's.
__________________
  #6
Old 11-06-2009, 11:39 PM
Default
Oh, and one more thing.
The bracket for the GPK is a flimsy piece of chrome plated steel. The tips of the bracket bowed as the radials moved around after tightening the bolts. I've yet to see it last through the winter. If the Balun doesn't work either, I may just get another antenna altogether. But I'm really trying to be a believer in the 2000 as long as I can. It's not really that bad of an antenna, but the ground noise is horrible & from my experience it is susceptible to a lot of interference.
Other than that, it transmits just fine.
Food for thought.
__________________
  #7
Old 11-08-2009, 06:51 AM
Senior Member
hotrod is on a distinguished road
Default
ihad a imax 2k and switched to a alummumin antenna.sirio2016.it doesnt pick up
all the noise and actually now im able to hear stations i couldnt hardly hear due to noise
heres anther test completely shut off all power to house and get in mobile and see if ya have any noise.if so drive around and find it.heres some culprits for this
1]touch lamps with various light settings
2]dusk to dawn lights outside when on at nite]
3]broadband router either yours or even just from a close neighbor[ive experienced this]
__________________
magnum delta force
magnum omega force
uniden grant
cobra 2000gtl
sirio z180
skythumper65dx
  #8
Old 11-08-2009, 11:05 AM
Supporting Member
W5LZ is an unknown quantity at this point
Default
There's no way around it, noise IS. There are things you can do to reduce that noise, and it sounds like you are in the process of getting there. The other bad thing about all this is that there are no 'standard' ways of getting rid of noise in every situation, every situation can be different.
Just from what I've read here, it sounds like the noise problem may be from the electrical line. It isn't that hard to 'clean' on line in your house, or just one device on a line. You are doing that with that power line filter. The problem with that is that the noise besides being 'conducted' can also be 'radiated'. You sure could have 'cleaned' that one device's power line, but is it also picking up that noise from the other lines in the house radiating it? Lots of possible sources. Only way to stop that is by putting one of those filters closer to the source, or at the meter to the house. You really don't want to know what those things cost! (Or that delrin )
Good luck!
(I doubt if I'd like it either, but 1.5 dB of noise really isn't much. The only times I've ever seen lower than that (or as low as that) has been when I've been completely away from town.)
  #9
Old 11-08-2009, 11:10 AM
Senior Member
HiDef is an unknown quantity at this point
Default
1.5 dB relative to what?
Do you mean 1.5 S units?
  #10
Old 11-08-2009, 12:40 PM
Supporting Member
Default
You're right, I shouldn't have used 'dB', should have just rounded things off and said 1.5 'S' units. I don't think I can distinguish 1.5 dB by my 'S' meter, that's what 1/4 of an 'S' unit? It's not like this was any sort of 'exact'. Oh well, col day, belly's full, think I'll take a nap.
if anything happens that's going to affect me directly, somebody wake me up. If I'm snoring, it better be important. You've been warned. OOOoo! A bug! I think I'll chase it!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Imax 2000 from Palco Rob KI6USW CB Antennas 10 10-09-2009 06:30 PM
SOLARCON ANTRON 99 VERSES THE SOLARCON IMAX 2000 TonyV225 CB Antennas 38 07-31-2009 03:42 PM
baluns towernewbie Amateur Radio Antennas 16 03-02-2008 05:11 AM
Mast size & Imax 2000 Height? Jerry Grandstaff CB Antennas 17 09-24-2005 10:55 PM
Powered by vBulletin®
