Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Convert MX-6707 Antenna Base Unit to CB
Reply
  #1
Old 10-18-2009, 09:42 PM
Junior Member
soup1967 is on a distinguished road
Question Convert MX-6707 Antenna Base Unit to CB
I have a truck that I am trying to maintain a military look. I have a couple of Mx-6707 Antenna Matching Unit bases with 8 foot military whips. I would like to convert the matching units for CB usage. Does anyone have any advice? Please Help! Thanks!
Worldwide Radio Forum
  #2
Old 10-18-2009, 10:06 PM
Rob KI6USW's Avatar
Senior Member
Rob KI6USW is on a distinguished road
Default
Yeah; but you might not like the answer.
You will need whips at 9 ft lengths - instead of 8 ft/96 inch lengths.
108 inch length is a 9 foot whip length = resonant CB length.
__________________
What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770.
"...The 444 in San Jose CA; the Central Gold Coast..."
  #3
Old 10-19-2009, 11:37 AM
Supporting Member
W5LZ is an unknown quantity at this point
Default
It can certainly be done. Since I'm not familiar with that 'matching unit', I can't give any advice about using it for matching that whip to 11 meter use. Depending on just how much trouble you want to go to, and if you think you may ever need that 'matching unit' in any kind of repairable/working shape, there are several ways of getting a reasonable match. Most of those 'ways' would involve destroying that thingy or just by-passing it. Not using that 'matching unit' and by-passing it would probably be the simplest way, but if you know much about radio stuff it will be noticeable, would that work for you?
  #4
Old 10-19-2009, 07:41 PM
Junior Member
Question Any help will work
I have already bypassed the unit by removing the guts and running #12 solid wire from the antenna mount to the bottom using solder to connect both ends per instructions on "Offroad.com". The questionis how do I connect to CB antenna COAX system?
  #5
Old 10-20-2009, 05:55 PM
Supporting Member
Default
Just from looking at the diagram of the bottom of that thing, I think I'd remove that multi-pin jack and substitute an SO-239 jack instead. A typical PL-259 plug on the coax will screw right onto that SO-239. That wire from the bottom of the whip would go to the center pin of that SO-239.
  #6
Old 10-20-2009, 07:24 PM
Junior Member
Default
Thanks 'Doc! I will certainly look into this configuration. Hopefully it works because it sounds alot easier than the procedure shown in the afore mentioned article on "flashoffroad.com". -KC
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
your favorite CB myth , lies and legends . BOOTY MONSTER General CB Services Discussion 74 10-23-2009 07:07 PM
1/4 wave groundplane & end fed verticals - time for some FACTS moleculo CB Antennas 31 03-30-2009 12:51 PM
Super C antenna...this is really neat moleculo Amateur Radio Antennas 8 12-10-2008 10:35 AM
baluns towernewbie Amateur Radio Antennas 16 03-02-2008 05:11 AM
Powered by vBulletin®
