Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Monkey Made
Reply
  #1
Old 10-18-2009, 10:01 PM
roaddog69's Avatar
Junior Member
roaddog69 is on a distinguished road
Default Monkey Made
I found my old MM5 coil only it was missing the stinger, so my question is does it matter how long the stinger is, can I put 102' stinger on it? or does it have to be what the manufacturers says 58 inchs?
Worldwide Radio Forum
  #2
Old 10-19-2009, 11:02 AM
BOOTY MONSTER's Avatar
Senior Member
BOOTY MONSTER is on a distinguished road
Default
the stinger length affects the tuning of the antenna . if the tuning is too far off it can dammage yout radio or amp . monkey made antenna also use a fatter stinger than most other antennas but a 102 cut to proper length should work fine if you cant find a actual MM stinger . use a external meter when you tune it .
__________________
  #3
Old 10-20-2009, 06:53 PM
mackmobile43's Avatar
Prestigious Member
mackmobile43 is on a distinguished road
Default
Quote:
Monkey Made Antenna Stingers
__________________
I U 212
  #4
Old 10-21-2009, 12:25 AM
roaddog69's Avatar
Junior Member
Default
thanks for the help guys
  #5
Old 11-17-2009, 02:48 PM
roaddog69's Avatar
Junior Member
Default
Just got my stinger for my mm5 today and its not like the 3/8 24 thread stingers,but the local cb shop said mine is different then other monkey mades he has seen,does monkey made use 3/8 24 thread for the stinger
  #6
Old 11-17-2009, 03:40 PM
TonyV225's Avatar
Senior Member
TonyV225 is on a distinguished road
Default
YIKES!!! Thats odd!!
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #7
Old 11-17-2009, 03:42 PM
kor b's Avatar
kor b is on a distinguished road
Default
Quote:
Monkey made uses 3/8 24 thread for the shaft (base of ant.)
The stinger has no threads.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
spring under a 10k or monkey made antenna BOOTY MONSTER CB Antennas 8 12-31-2006 09:05 AM
So how fast can i go with a big monkey made before it snaps? subs757 CB Antennas 0 01-18-2005 01:16 PM
Monkey Made and Predator 10k tejanodrum CB Antennas 2 12-26-2004 05:26 PM
Monkey Made don't like Watts fortymobile CB Antennas 29 12-26-2004 09:09 AM
Monkey Made Antenna Dirty Green CB Antennas 0 03-07-2002 11:26 AM
Powered by vBulletin®
