Booty M',
"but it does clash with coax length supposedly suppose to not affect vswr"
Ah, but that not affecting SWR because of length has a 'catch' to it. That catch is that the load/antenna on the end of that coax is resonant and properly matched to the feed line's impedance. If the antenna's right, feed line length just doesn't matter.
Hang on, it get's even better!
Because reactance changes with frequency, if that reactance is chosen correctly and put in the right place, the further you get away from a resonant frequency, those changing reactances can make the whole thing -appear- to still be resonant and impedance matched. One particular antenna type that comes to mind very quickly that takes advantage of that is a 'Bazooka', and there are others that are common on the
CB market, the one's that appear to have a low SWR from daylight to dark, broadbanded like the devil! Why? Cuz they are -not- being 'measured' with a fool proof meter. Think about it...
