Quote:
Originally Posted by BOOTY MONSTER
how does coax length affect antenna tuning length ? |
BM, this has been my experience. If the antenna is tuned perfectly at resonance and shows no reactance, then you will not likely have any transformation in the system and the feed line will appear transparent to the system. Of course the connectors have to be perfect too.
In most cases this does not happen and the feed line will be somewhat reactive. A lot depends on the amount of reactance at your choice of frequency (center) and then the feed line will become a part of the radiating system and then to some degree the longer the line the longer the radiator will appear and the lower the frequency. I
am not sure if this condition is linear curve (/)or takes the form of a sinus curve (~).
Line theory is complicated and there is more to this issue, but that is my short story.
