Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Best Mobile CB antenna
Reply
  #41
Old 11-02-2009, 06:34 PM
mackmobile43's Avatar
Prestigious Member
mackmobile43 is on a distinguished road
Default
I took out 2 rows of 8' florescent tubes with my 27'' shaft 10-k at the local Ace hardware.
__________________
I U 212
Worldwide Radio Forum
  #42
Old 11-02-2009, 08:07 PM
Senior Member
hotrod is on a distinguished road
Default
Quote:
Originally Posted by Rob KI6USW View Post
I just finished reading all nine pages of that thread.
I recommend that read.
THNX - BootyMon!
But this thread/link also raises some more questions:
Is the Sirio Z-180 the ULTIMATE base load antenna?
Should I forget about the Sirio 4000 in favor of the Sirio Z-180?
Do they still make the Sirio Z-180?
Or would I do as well by putting a larger diameter stinger/whip on my Wilson 1000?
sorry to my best of knowledge the z180 isnt advailable.i got mine from coppers in 07 or 08?you will see a noticable gain .however it wont be huge.at 20 miles my wilson with a stock 68 showed signs of fading signals .so i stoped screwed on on sirio i was
being heard again as well i was hearing my base.there was only a 1-sunit increse but hey that was the differece between not being heard and being heard.i drove other direction i has slightly better results.i seen almost 2 -s units.sooo thats why i said 1-2 sunit increase
__________________
magnum delta force
magnum omega force
uniden grant
cobra 2000gtl
sirio z180
skythumper65dx
  #43
Old 11-04-2009, 10:08 PM
Junior Member
russ is on a distinguished road
Default
THNX - BootyMon!
Hi Rob,
I have one of those Z-180 antennas that I bought last year but was not able to get a good SWR reading as the 1000 had..if you are interested I will let you do give it a sample test on your current set up and see if it works well for you...
I will contact you on the band.
Russ
  #44
Old 11-04-2009, 10:36 PM
Rob KI6USW's Avatar
Senior Member
Rob KI6USW is on a distinguished road
Talking
Quote:
Originally Posted by russ View Post
Hi Rob,
Russ
Awright Russ!!!
I'm glad you joined the forum...Too cool!!!
Sure I'll try it out...and review it...
__________________
What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770.
"...The 444 in San Jose CA; the Central Gold Coast..."
  #45
Old 11-06-2009, 07:15 AM
Junior Member
JC_enfield is on a distinguished road
Default .
well It looks like the Sirio Hi Power 3000 and 4000 are the best mobile antennas it seems.
I do have a 9ft tank whip which i am going to try next time i am static mobile and see how well it peforms against the sirio's
Thanks for all of your input.
Many thanks to Bob and Delta for helping me clear this one up
73's
  #46
Old 11-06-2009, 08:18 PM
Rob KI6USW's Avatar
Senior Member
Default
I got a Sirio Z-180 from Russ - for the purpose of writing a review. I will set it up on my vehicle tomorrow - so that the SWR is correct when I switch between the Wilson 1000 and the Sirio Z-180.
I will be using a Wilson mag-mount, a Honda CR-V, Galaxy 99V, and a Astatic D-104 from my end. Russ will choosing his best radio (out of 100's of them!!! - no joke) to test the receve at his end. As well as me seeing the difference or receive at my end - I will attempt to make this as thorough evaluation as I can.
I'll start another thread this Sunday with the results and happenings of this Wilson 1000 vs the Sirio Z-180 'shootout'...
__________________
What gear do I use?
  #47
Old 11-06-2009, 08:47 PM
555 555 is offline
Senior Member
555 is on a distinguished road
Default
Quote:
Originally Posted by mackmobile43 View Post
This is what one guy at the other forum has to say: "
the coil is probably grounded at the base and tapped for the 50ohm feed point on the reverse side of what is shown in the cutout picture of the base coil."
LOL, there is no point of contact for ground until you get to the base of the antenna so tapping the coil before you reach that area is still no good. Here is the link for the 300 and 4000 series which is possible that dc ground is there.
Sirio Antenne - Products
But on the 5000 series there is a single section that pivots and is the only path from the antenna to the base so there can be no shunting before the pivot section and it would have to be in the base so tapping the coil is impossible before the pivot.
Pictures don't lie.
this is whats the fuss all about??????????
i put my Predator 10K up against them any day
with half the watts
__________________
As such the device is not protected against interference and the parties operating such a device can not seek redress from parties operating radio communication services. In other words they do not get protection from interference and thus must accept interference. Because of this, any part 15 device should be designed to operate robustly under all conditions
  #48
Old 11-06-2009, 08:59 PM
Prestigious Member
Default
with half the watts
The fuss is about them being dc grounded not whether they'll out perform any other antenna.
__________________
I U 212
  #49
Old 11-06-2009, 09:04 PM
Senior Member
15minigrass is on a distinguished road
Default
Still nothing beats the KING 102". PERIOD!!! But i love my 10K!!!
__________________
Mobile:
Prez Grant Export
Black Widow 350V
9" Predator 10K
RS SWR/Watt Meter
Base:
Soon to be "COBRA 2000"
Pyramid 25 Amp P.S.
partly assembeled Starduster/ works well too, 1.3:1 SWR....
  #50
Old 11-06-2009, 09:12 PM
555 555 is offline
Senior Member
Default
being dc grounded not sure
but i still put my 10k up against those things and i go up against a 102 whip just for grins
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
your favorite CB myth , lies and legends . BOOTY MONSTER General CB Services Discussion 74 10-23-2009 07:07 PM
1/4 wave groundplane & end fed verticals - time for some FACTS moleculo CB Antennas 31 03-30-2009 12:51 PM
Super C antenna...this is really neat moleculo Amateur Radio Antennas 8 12-10-2008 10:35 AM
baluns towernewbie Amateur Radio Antennas 16 03-02-2008 05:11 AM
Powered by vBulletin®
