Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
pics of progress on the homebrew 5/8
Reply
  #1
Old 10-31-2009, 06:09 PM
BOOTY MONSTER's Avatar
Senior Member
BOOTY MONSTER is on a distinguished road
Default pics of progress on the homebrew 5/8
ive got what i can on it done for the moment , just need a dry day and some help taking the homebrew 1/4wgp down and putting the new one up . gonna pull the ground radials off the 1/4 and use them on the 5/8 . and of course ill have to tune it after the grounds are on .
ill be using the ground wires and X off of this 1/4wgp on the 5/8 .
the ground radials/wires and the coax shield will attach to the bottom of the tuning ring on the single bolt .
i used noalox on the tube sections and between the radiator and tuning ring behind the 2 bolts on the verticle . those 2 bolts give a super tight and very solid connection and the ends make a nice little saddle for the u clamp to rest in and keep the antenna from sliding down......just in case the pressure treaded 2x4 shrinks enough to allow that .
i also used some plastic tubing on the U clamps so they wouldnt be a radiating part of the antenna .
for a temporary tuning place i put a 2 foot 2 inch pve pipe in a hole and im using a 10 foot 1 1/2 inch peice of pvc for a mast . pull it out for adjusting vswr and stick it back in to see what it is .
the center coax conductor will be held in place on the tuning ring with a wooden clothes pin for checking and setting vswr and then a hole will be drilled in the ring at best tuning place and and a ring terminal and SS nut and 2 bolt with a lockwasher will secure it . every nut and bolt has a flat washer and a lock washer .
the verticle is 22 1/2 feet tall and theres 6 inches of over lap on each section . theres just a simple rubber cap on the top . i do expect the vswr to possibly rise a point or 2 from tuning the feedpoint 9 feet off the ground to 23-24 feet in the air , but if i can get to 1.2 or less on the ground that wont be a issue in the real world .
a few more pics ....
with the verticle not fully telescoped it about 8 - 8 1/2 feet tall .
seems like its taking me forever :Frustrated: but it is comming along :yes: .
i hope to have it up and talking in the next few days . ill post a few more pics with it in the air and the ground elements installed when its up .
if you see where ive made any mistakes let me know !! :Laugh:
__________________
Worldwide Radio Forum
  #2
Old 10-31-2009, 06:35 PM
Rob KI6USW's Avatar
Senior Member
Rob KI6USW is on a distinguished road
Default
Q: Are you using a field strength meter to see how well it is radiating? Or are you going to depend upon reports from friends in your area to tell you how many S-units you are hitting them with? Materials look decent enough. I take it that the ring is replacing the need for a matching coil? Is a balun going to built for a part of this? Inquiring minds want to know...
__________________
What gear do I use?
BASE: Icom IC-718 & GAP Titan DX, Yaesu FT-8800R & Diamond X50A, Magnum OmegaForce S45 & IMAX 2000 w/Astatic D104/TUP9.
MOBILE: Galaxy DX99V & Wilson 1000 w/Astatic D104-M2, Yaesu FT-8800R & Diamond NR-770.
"...The 444 in San Jose CA; the Central Gold Coast..."
  #3
Old 10-31-2009, 06:45 PM
Senior Member
Default
just a vswr meter (astatic 700) and local reports . no balun but i will be using a coax choke about 9 feet below the feedpoint . the ring is for matching , similar to hjow a maco 58 tunes but done according to wizardos measurements .
Tips and tricks on how to build your own CB Antennas.
i wish i had access to a mfj analizer , but nobody has one
__________________
  #4
Old 10-31-2009, 07:03 PM
Highlander_821's Avatar
Amour d'Ecosse
Highlander_821 is on a distinguished road
Default
That looks great so far. What a nice, simple design. I bet it will work very well for you.
__________________
Highlander, NA-821 on 11 Meters.
N9RZF, David on Ham Bands.
Yaesu FT-847, Galaxy DX-2517, President Lincoln, Cobra 150 GTL, Uniden Grant LT.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maco 5/8 vs. sirio 827 ?????? BOOTY MONSTER CB Antennas 5 11-20-2009 08:14 AM
5/8 mobile antenna question BOOTY MONSTER CB Antennas 7 08-20-2009 05:14 PM
pics of my homebrew 1/4wgp BOOTY MONSTER Station & Mobile Pics 2 08-06-2009 07:46 AM
sigma 5/8 or maco 5/8 , which is better ? BOOTY MONSTER CB Antennas 4 12-29-2008 07:05 AM
Hi All, Pics Of My Junk rat 77 Station & Mobile Pics 6 05-05-2005 08:37 AM
Powered by vBulletin®
