Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Looking For Way To Better Mount SUV Antenna Or Other Options
Reply
  #1
Old 10-31-2009, 08:39 PM
Junior Member
RBeach is on a distinguished road
Default Looking For Way To Better Mount SUV Antenna Or Other Options
I have my CB installed in a Nissan Pathfinder. Previously, I had it mounted to a bracket, which ran to the inside part of the lift hatch. Unfortunately, I was getting some bad noise, and it appeared to be stemming from the rear window defroster (at least I think).
I moved it to the right rear passenger door frame, and have the bracket coming out. I have got my SWR down to about 1.5, maybe a little lower.
My problem is, when the door opens, one of the bolts for the mount scrape the door just a hair.
Any ideas? I had considered a magnetic roof mount, but my problem runs into that I park in a parking deck at work ever day.
By the way, the antenna I have on there is a Wilson 1000 (I believe). It is a 3' fiberglass antenna.
According to what I gather, I can get only about 10-12 miles out sitting in my driveway at night (this is through the woods and over the river).
Thanks.
Worldwide Radio Forum
  #2
Old 11-01-2009, 06:53 AM
Senior Member
Lazarid Anarion is on a distinguished road
Default
Hmm I just looked at some pictures of a Pathfinder online.If your Pathfinder has a tire rack on the back ,that would be a spot to mount an antenna of some sort,maybe a 4 foot fiberglass whip type,such as a Firestick 2 for example,or mount a small plate for a base loaded antenna of some kind,a Wilson 3k or 5k for example.
Or maybe if your Pathfinder has the rack on the top you can mount an antenna on it if you can get the mount grounded to the body without much trouble.There are monuts that I have seen in various ham radio catalogs that will swivle around to the point that the antenna will be laying down to allow you to drive low clearance areas.
I am sure there are other options out there,those are what I could come up with off teh top of my head this early in the morning
As far as your range out of a moble goes, that will vary with the antenna type,power you are running if any ,area you are in,if you are on a hill top or down in a hole,city or out of town areas,buildings make a huge difference as to how well you can get out, and conditions on the band (if there is high noise levels ,skip and so forth) as well as the type of set up the person you are trying to contact has( if they are moble,base....so on) SWR isnt an issue on your current set up,1.5:1 isnt anything to be to worried about.
10 to 12 miles moble to moble AM mode,no extra power on avarage isnt to bad but can be better of course.
Also if you could post the type of radio you are running,power output of radio,if you are running extra power,output of that would be nice as well,that would give us a bit more to go on...thanks !!
Last edited by Lazarid Anarion; 11-01-2009 at 07:08 AM. Reason: added another thought
  #3
Old 11-01-2009, 08:33 AM
Junior Member
Default
For the moment, I am running an el cheapo Maxon MCB-45W in there ( got it real cheap). That will change soon. I got my hands on a Cobra 29 LTD Classic and a 29 WXNWST.
Unfortunately, I do not have the tire rack (mine is under the vehicle). I had thought about the rof rack, but can't seem to find a way to mount to it. The two cross bars that are in front and back, I am a little leary. They tighten down with these wheel type things, and worried they might work loose and antenna come off going down the highway.
I am leaning towards the roof top mag mount, possibly.
  #4
Old 11-01-2009, 09:02 AM
Senior Member
Default
There are several base loaded mag mount antennas out there that will give you good performance,Wilson 1000,3000,and 5000 just to name 3,and I am sure there are serveral more out there as well . The magnet mount option will let you remove and reset the antenna for going under low areas easily.
I do know there is a ham radio trunk lip mounted system ( it attaches to the trunk edge just like a CB trunk lip mount antenna) that swivels to almost any setting so the antenna will stand virtical.I think there are mount models that has the 3/8 by 24 threads ( like what the Firestick fiberglass whips have for attaching to a mount) that would work
The Diamond K-400 3/8C mount is one I am thinking of,do a google image search for a pic of the mount
  #5
Old 11-01-2009, 09:11 AM
Junior Member
Default
Of those Wilson antennas, will the 39" loaded whip antennas ones work well?
  #6
Old 11-01-2009, 09:20 AM
555 555 is offline
Senior Member
555 is on a distinguished road
Default
solid mount it on top about a foot from the rear
get a puck mount and a 17 inch shaft Predator 10k Comp coil
213 coax or lmr 240
__________________
As such the device is not protected against interference and the parties operating such a device can not seek redress from parties operating radio communication services. In other words they do not get protection from interference and thus must accept interference. Because of this, any part 15 device should be designed to operate robustly under all conditions
  #7
Old 11-01-2009, 10:42 AM
Senior Member
Default
Any of the Wilson antennas work great that I mentioned,depends on how much you are willing to spend
  #8
Old 11-01-2009, 04:17 PM
Senior Member
hotrod is on a distinguished road
Default
roof mounted wilson trucker antenna or predator10k on a quick dicconnect mount
__________________
magnum delta force
magnum omega force
uniden grant
cobra 2000gtl
sirio z180
skythumper65dx
  #9
Old 11-01-2009, 04:31 PM
Senior Member
moleculo has disabled reputation
Default
Check out some of the groove mounts made by Diamond. They mount flush between the door grooves. They're pricey, but they are very strong. You could even run a Wilson trucker style antenna on one of those mounts if you felt like it.
  #10
Old 11-01-2009, 05:33 PM
555 555 is offline
Senior Member
Default
i thought this was his question
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
your favorite CB myth , lies and legends . BOOTY MONSTER General CB Services Discussion 74 10-23-2009 07:07 PM
1/4 wave groundplane & end fed verticals - time for some FACTS moleculo CB Antennas 31 03-30-2009 12:51 PM
Super C antenna...this is really neat moleculo Amateur Radio Antennas 8 12-10-2008 10:35 AM
baluns towernewbie Amateur Radio Antennas 16 03-02-2008 05:11 AM
Powered by vBulletin®
