Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Home brew base ant!!!
Reply
  #1
Old 11-28-2009, 11:21 PM
Senior Member
15minigrass is on a distinguished road
Default Home brew base ant!!!
O.K. I took a Junction box or some kinda electrical box that you can remove the caps by bending it to break. Anyways, I mounted on a Gumball mount into one of the holes, used the wire clamp and inserted one of the groundplane rods from my Starduster and clamped it into the junction box, then screwed on my homemade fightingsticks from my starduster groundplane rods. It is in a "L" like configuration. I was wondering if this will make it directional or omni????
Both elements are the same lenghts. I used my SWR meter and it read 1.5:1 SWR.
All I wanted to know if it will be directional if I have only one element on one side of the antenna?
Most of the interference/RF interference with this setup have disappeared as when I had the partial stardust up. But, just waiting for some condition to test it out if it really works well.
Thanx, James. Ill try to get some pix by tomorrow.
__________________
Mobile:
Prez Grant Export/Stock Mic
Black Widow 350V
Two 9" Predator 10K
RS SWR/Watt Meter
Base:
P/T COBRA 146GTL(Spare)
President Jackson
Turner +3 Hand Mic
Pyramid 25 Amp P.S.
Home Made Ground Plane Base ant.
  #2
Old 11-29-2009, 07:07 AM
Senior Member
Location: Coulterville Illinois about 40 miles southeast of St.Louis Mo.
ron103067 is on a distinguished road
Default
Not sure about yours but I know a guy that did his with a 102 whip and another mobile antenna in the L shape and he said his wasn't directional so yours will probably be omni now I am looking to do something like that and I am going by what he said so let me know how it works for you
  #3
Old 11-29-2009, 08:33 AM
IMD262's Avatar
Senior Member
IMD262 is on a distinguished road
Default
It sounds like have made a 1/4 wave ground plane, like the ones that were available back in the hey day of the 70's for mounting on you window sill or balcony.
  #4
Old 11-29-2009, 11:48 AM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
No, it won't be directional to any extent.
  #5
Old 11-29-2009, 12:39 PM
BOOTY MONSTER
Guest
Posts: n/a
Default
i would have thought the antenna would have been directional in tx and rx in the direction of the single ground radial . the same way a mobile antenna has more tx and rx to the front of the vehicle if you mount the antenna at the rear of the vehicle . or the opposing front corner if you mount it on a rear corner .
  #6
Old 11-29-2009, 04:13 PM
Senior Member
NorthStar has disabled reputation
Default
Interesting
  #7
Old 11-29-2009, 04:26 PM
Senior Member
Default
Hey Booty, thats Quicksilver's pix. Here is mines.
Quote:
Originally Posted by BOOTY MONSTER View Post
these are pics 15 posted of his antenna on another forum
__________________
Mobile:
Black Widow 350V
Two 9" Predator 10K
RS SWR/Watt Meter
Base:
President Jackson
Turner +3 Hand Mic
Pyramid 25 Amp P.S.
  #8
Old 11-29-2009, 04:32 PM
Senior Member
Default
how does it perform?
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/cb-antennas/37356-home-brew-base-ant.html
Posted By For Type Date Hits
Home brew cb antenna This thread Refback 12-24-2009 09:23 AM 10
Similar Threads
How To: Use crossband repeat legally on your base station Moleculo VHF/UHF Bands and VHF/UHF Rigs 32 10-04-2009 07:43 PM
home brew noise toys john52732 Home Brew 3 05-07-2009 08:56 PM
First ever home brew antenna project.... WX2MIG Amateur Radio Antennas 30 01-11-2009 10:38 AM
home brew base antenna questions BOOTY MONSTER CB Antennas 1 08-31-2008 04:43 PM
Delete the Home Brew section Hook948 General CB Services Discussion 15 01-04-2004 01:29 PM
Powered by vBulletin®
