Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
IMAX 2000 Ground Plane Kit...
Like Tree1Likes
  • 1 Post By Needle Bender
Reply
  #1
Old 01-31-2010, 06:08 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Cool IMAX 2000 Ground Plane Kit...
I just picked up a ground plane kit for my IMAX 2000 today that I bought used from a local operator. He is a new member to this forum. His name is Brian 264 and is also a member of The World Radio Club -"WR-264".
The kit is rather straightforward. Four fiberglass radials at/about 70 inches in length. They bolt to a 1/16 inch angle plate that also bolts to the IMAX mount. The angle of the radials appear to be about 35 degrees downward - that is a guesstimate. The whole thing couldn't weigh more than a pound or two - it's real light. The mount itself is flash chromed. Which is coming off in large sheets and the shards are razor sharp. I'll probably wire brush the daylights out of it to remove all loose chrome, and then spray it with some silver or aluminum paint - so it won't rust. But otherwise it is in decent shape.
I will install it on my IMAX and re-tune the SWR on the antenna before the Gizmotchy Beam review that is coming up soon...maybe by this weekend if everything goes as planned...the Gizmotchy beam should be here tomorrow - I'll post pics...
Gizmotchy Beam Antenna...Coming Review
Here is a drawing of the IMAX ground plane kit. The radials are much longer in real life as compared to this drawing.
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
  #2
Old 01-31-2010, 10:14 PM
Robb's Avatar
Yup
Default
BTW - Is there a easy means to get a hold of some conductive grease?
I want to get something that will keep parts from rusting but not interfere with electrical continuity.
Or will I have to go to a specialty store for what I need?
Any particular brand name(s)?
__________________
  #3
Old 01-31-2010, 11:41 PM
BOOTY MONSTER
Guest
Posts: n/a
Default
lowes carries NOALOX . thats where i got mine from .
its also a good lubricant for grocery cart wheels .
  #4
Old 02-01-2010, 05:01 AM
hookedon6's Avatar
hookedon6 is on a distinguished road
Default
i'm hearing that some ops are replacing the (short, 70 inch) radials with 1/4 wave ss whips with good results.
NOALOX is good stuff . i always use it on any metal fasteners
  #5
Old 01-15-2012, 06:30 PM
IDIeselman's Avatar
Senior Member
IDIeselman is on a distinguished road
Default
Two year later and the weekend still eludes us. What happended with the install of the GP kit?
  #6
Old 01-15-2012, 09:06 PM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
He must have fell while installing them LMAO!!
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #7
Old 01-15-2012, 09:38 PM
Robb's Avatar
Yup
Default
I never installed the GPK. Going to put the Imax on top of the 4 element beam instead. Gonna keep the GPK and sell it with the Imax if/when I decide to sell it. But for now, I use it for mostly local talk.
__________________
  #8
Old 01-16-2012, 01:45 AM
Needle Bender's Avatar
Senior Member
Needle Bender is on a distinguished road
Smile
Robb the beam will make a better radial system anyway. But for that much effort and so you don't have to redo it sooner than you would like, why not order a new Penetrator, leave off the radials and use it up through the beam instead?
You know those imax eventually have swr problems due to water ingress, and I'll bet you could sell it locally especially with a radial kit and offset the cost of the P500.
Just sayin'
Slim likes this.
Reply
Bookmarks
Tags
cb antenna, gizmotchy, ground plane radials, imax 2000
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/cb-antennas/43349-imax-2000-ground-plane-kit.html
Posted By For Type Date Hits
IMAX 2000 Ground Plane Kit... This thread Refback 01-31-2010 06:42 PM 1
Similar Threads
Your Thoughts on an Imax 2000 + ground plane kit. King Mudduck CB Antennas 40 05-28-2012 05:05 AM
Crackling 60hz hum three channels in a row, every 4th channel clear as a bell. cominatyalive CB Band and CB Radios 97 01-28-2011 04:31 AM
isolation from mast Splash1 CB Antennas 71 03-17-2010 09:23 PM
Recommend Ground Plane Kit For Imax 2000? Wire Weasel CB Antennas 51 09-19-2009 06:16 PM
Imax Ground plane kit for dx or not? wallyneumonic CB Antennas 1 12-30-2004 06:56 AM
Powered by vBulletin®
