Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
maco boomer ground plane kit
Reply
  #1
Old 03-27-2010, 06:57 AM
BOOTY MONSTER
Guest
Posts: n/a
Default maco boomer ground plane kit
anybody have any experience or know anything about this add on groundplane kit ?
any idea how durable it is ?
MACO :: Products>Antennas
http://www.eagle1com.com/storepp/antennas/maco/GPRK.pdf
this place has them for $40 + S&H . (yes a pic of the 107 , not the boomer)
Electronic Service Center
anybody know anything about Electronic Service Center ?
anyhow ..... looks to be 7 foot aluminium elements that attach to a hub that fits over the mast/pipe with a few set screws for attaching to the mast . neither maco or the pdf state what size pipe the hub would fit on , does anyone know ? 1 1/2 - 1 5/8 would be perfect .
eagle has it for $40 bucks , i figure 10-15 for shipping so its about the same price as just ordering the tubing id need from DX Engineering but i dont have to figgure out and fab and a mounting plate for the ground elements .
  #2
Old 03-27-2010, 07:04 AM
Senior Moment
Wire Weasel is on a distinguished road
Default
No experience Booty but this does look interesting. Sturdy horizontal GP kit and the price is right. Probably easy enough to extend out to 9' if wanted with a little extra tubing.
I like it
__________________
Welcome to the WWRF. Plenty of Free Parking and with 5,000 posts you get egg roll
  #3
Old 03-27-2010, 07:21 AM
BOOTY MONSTER
Guest
Posts: n/a
Default
according to the pdf the longer elements are 1/2 inch so the 3/8 inch by 3 foot tubing from DXE would be perfect for extending them .
Aluminum Tubing Type 6063 - 3 ft.
a little less than $18 including shipping to my area .
from what i can tell 1/2 waves and 5/8 or .64 wave length antennas arnt as dependant as as 1/4 waves on needing full 1/4 wave length ground elements . so 7 footers may be good enough . the sirio seems to be a very good performing antenna (outside of it liking to go open circuit of the matching coil) and it uses short ground elements just over 4 ft long and their 2000 series ground elements are just over 2 foot long , but they're are more of them .
  #4
Old 03-27-2010, 08:10 AM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
Just something to think about...
There's really no great benefit in using 'horizontal' groundplane elements over the 'drooping' kind. All that 'droop' does is provide a means of raising the input impedance of the antenna. with a typical 1/4 wave vertical the input impedance is going to be lower than 50 ohms, so some 'droop' is one way of raising that to where you want it. With a typical 5/8 wave vertical the input impedance is also low, but is at least partially 'made right' by the matching coil. That means that the angle of the dangle for the radials can be almost anything and still work well (depends on the 'tap' on that matching coil). All the 'hype' about the angle of the radials is just exactly that, 'hype', has nothing to do with radiation angles. Don't get too tied up with it.
(What's that got to do with the subject? Not much, but it can certainly complicate things unnecessarily.)
  #5
Old 03-27-2010, 08:58 AM
BOOTY MONSTER
Guest
Posts: n/a
Default
hey doc
i was just thinking of easy ways to clean up the looks of the antenna when i put it back up . i really wasnt expecting much difference from using the X as a standoff and wires comming down to it . i may do that again though , it did very well with it and really woke my ears up to where i very rarely could not hear someone that was herd by others within a few miles of my 20 . its very cheap too
  #6
Old 03-27-2010, 10:21 AM
Senior Member
JoeDirt is on a distinguished road
Default
Hey Booty, thats the same ground plane the Maco base antennas come with! I had 2" of ice buildup on my ground radials last year! I think there really durable!
  #7
Old 03-27-2010, 10:40 AM
Jock Supporter
mackmobile43 is on a distinguished road
Default
Quote:
Will that spider hub fit over 1 1/2'' tubing?
  #8
Old 03-27-2010, 12:45 PM
Marconi's Avatar
Supporting Member
Marconi is on a distinguished road
Default
Hey BM, this boomer kit is meant to replace the GPK on fiberglass antennas which have a base that is 1.25" in diameter. They will install on any antenna base mount that will accommodate the application.
You and Joe are right, however, if you want to extend the radials out to 105", like the V58, but Joe unless I read the facts wrong, I disagree. I think this boomer kit is shorter than the one on the V58.
Reply
Bookmarks
Tags
ground plane radials, maco antenna
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
IMAX 2000 Ground Plane Kit... Robb CB Antennas 7 01-16-2012 01:45 AM
Crackling 60hz hum three channels in a row, every 4th channel clear as a bell. cominatyalive CB Band and CB Radios 97 01-28-2011 04:31 AM
isolation from mast Splash1 CB Antennas 71 03-17-2010 09:23 PM
assembly questions about maco 5/8 ground plane jrobinson CB Antennas 6 02-27-2009 09:47 PM
Ground Plane Kit Question this_is_nascar CB Antennas 4 01-01-2009 09:26 AM
Powered by vBulletin®
