Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
IMAX 2000 VERSES THE SOLARCON / ANTRON 99
Like Tree3Likes
Reply
  #1
Old 05-15-2010, 06:43 PM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default IMAX 2000 VERSES THE SOLARCON / ANTRON 99
I know this has been talked about before and with new members here maybe we have more answers or info. I want to know or hear about any differences between the Imax 2000 and the Antron 99 I am asking because I have always and currently have a Solarcon 99 up for 10-17 meters and also have a Imax 2000 in the pile or collection of antennas and was thinking about if it would be worth taking the Antron 99 with Groundplane kit down and putting the Imax up in its place and if I should buy the groundplane kit adon for the Imax aswell.
Is there a big noticeable difference in the performance between these 2 antennas??? Ive always had good luck with the Antron 99 and have not one single complaint but if this Imax 2000 is better and worth swapping with the Antron Ide do it tomorrow. What are your thoughts and or experiences with these antennas compared to eachother??? Ive heard people say that locally the Imax was better and as far as skip or DX the Antron was better I imagine if this was true it would be due to the take off angle between the 2 antennas but it still does not seem that there could be such a dramatic difference between the 2 antennas as far as local or close talking.
What is the truth here what are the differences are they really that noticeable?? I figured since I have an Imax here if its worth putting up I will do just that but if its not worth doing then what is the sense?? Also what about the groundplane kit?? Ive been told The kit for the Antron 99 is a waste of money and makes no difference I wouldnt know because Ive always ran the kit on my Antron 99 antennas. Thanks for any input and info on this mystery.....Tony
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #2
Old 05-15-2010, 08:23 PM
Senior Member
PA629 is on a distinguished road
Default
Last year I replaced a slightly damaged A99 (cracked f'glass) with a used Imax. Locally I picked up "about" 1/2 S unit or so, according to a reliable source. Exact same mounting scheme, same coax, etc. FWIW.
I don't know about DX performance, I use my directional arrays for that. Just my $.02.
Grim Reaper likes this.
__________________
Mobile #1: Galaxy 95T2, 2018 Extreme, Sirio P5000, 4x2879 LipZipper
Base: Cobra 2000GTL, D-104SE, A-99, 2 element quad,4 element yagi, Firebird 500, SB-220
  #3
Old 05-15-2010, 08:57 PM
Marconi's Avatar
Supporting Member
Marconi is on a distinguished road
Default Check out my signal reports in my album
Tony, these are signal reports I took last summer comparing some of my antennas. I compare two at a time using a switch box and I'll grant you this is not even close to scientific. They were taken over a 1-3 day periods in some cases and less than one day in others. I'm too old to go rushing around trying to change antennas and test on the same setup. Plus I get the advantage of comparing differences in the flip of a switch, and if you have never done that, then you just miss out on some, maybe all of the scuttle differences that can be noted between different antennas at times.
At my location I would leave the A99 up there bar none.
  #4
Old 05-15-2010, 09:05 PM
BOOTY MONSTER
Guest
Posts: n/a
Default
the 2000 is a better constructed antenna and most folks that have had both say the bigger imax is better . comments on adding the ground plane kit vary from no effect to big difference . both the 99 and 2000 will use your mast/coax shield for a ground plane if you dont add one . some folks that had splatter issues and bleeding into nearby electronics without the GPK said the were reduced or eliminated by add the GPK . a coax choke 9 feet down the coax from the antennas feed point is a good idea .
id want a proper elevated ground plane on any elevated omni antenna myself .
The Imax 2000 EXPOSED!
http://www.marktruett.com/files/a99.pdf
  #5
Old 05-15-2010, 09:07 PM
TonyV225's Avatar
Default
Wow very cool and thanks for sharing this!! And yes I do have different antennas set upfor different things but 3 are on a switch box and I do switch it up it seems each one has its pros and cons.
__________________
  #6
Old 09-15-2011, 04:34 PM
walterb is on a distinguished road
Default
T225,
Tony,
I use a A99 after doing direct testing of both antennas at 5-10-15-20 & 25 miles to a mobile on both T & R on 11 meters. I tested an IMAX an a A99 on 10-12 -15 -17 & 20 meters an got a shade better SWR with the IMAX over a A99 for HAM needs eather antenna is a lot of bang for the buck..........Oldtimer
  #7
Old 09-15-2011, 06:39 PM
Marconi's Avatar
Supporting Member
Default
Quote:
Originally Posted by walterb View Post
T225,
Tony,
Again I have to agree with Walterb, I've seen very similar results with these two antennas at my location. I have added the GPK, both horizontal and slanted, to the A99, with little noticeable difference. I don't have a GPK for my Imax. I also never used these antennas for anything except 11 meters.
I just posted in another thread, my comparison results between my A99, and my I-10K, and I'll post it again here just as a reference. Like the I-10K, my Imax was not up very long, and I only have one signal report (#25) for it.
Recap of Signal Reports 20 - 23.pdf
Signal Report # 25.pdf
__________________
Marconi's YouTube Channel
We're just lucky that Mother Nature doesn't require our antenna systems to be perfect in order to work our radio.
  #8
Old 09-15-2011, 07:36 PM
Smile A99 IMAX2000
Marconi,
I tried adding ground plane to both the A99 and the IMAX, a slight SWR change was noticed on 11 meters, more on other bands but that is understandable.
I did not detected changes against a reference antenna on R or T
on the A99 on 11 meters, do think the noise floor changed a little on the IMAX but I can't prove it ether, I had read that another person thought that he thought it did. Could have preprogramed myself to hear something like that................Oldtimer
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
IMAX 2000 Ground Plane Kit... Robb CB Antennas 7 01-16-2012 01:45 AM
SWR ON A IMAX 2000 cominatyalive CB Antennas 76 07-11-2010 01:00 AM
Another Imax 2000 Question movrider CB Antennas 1 10-25-2009 05:37 AM
Imax 2000 from Palco Robb CB Antennas 10 10-09-2009 05:30 PM
SOLARCON ANTRON 99 VERSES THE SOLARCON IMAX 2000 TonyV225 CB Antennas 38 07-31-2009 02:42 PM
Powered by vBulletin®
