Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Hello, Input on vector 4000 antennas
Reply
  #1
Old 07-12-2010, 01:20 AM
Junior Member
101 S/E Mich-Jim is on a distinguished road
Default Hello, Input on vector 4000 antennas
Hello to all ,first time post ,actually first time using a forum,Please bare with me! Been looking for a replacment antenna, been using an starduster (1/4 wave) antenna and lacking the reception that im searching for.I have seen several claims on the vector 4000 from better then a 5/8 wave to stating that it,s a 7/8 wave. So as the db claims differ from different suppliers. I'm am not concerned with the wind survival rate( I have some ideas on how i'll handel that). Can anyone enlighten me to the true facts about this antenna??? and if there's any updated vector 4000 antennas( some pictures show a wire ball on the top of some of these antennas while others do not. Also open to other omni antennas that will get me as much or more db gain. Any mods to this antenna that help with static or unwanted interferance. Thanks and look forward to Your input. 101 Jim
  #2
Old 07-12-2010, 03:38 PM
Junior Member
Default
No responce??? so no knowledge on actual spec or mods besides what is actually posted on your site????.... 101 S/E Mich- Jim
  #3
Old 07-12-2010, 04:03 PM
HomerBB's Avatar
Senior Member
HomerBB is on a distinguished road
Default
Good to have you here on the forum. You aren't the only one wanting the answers to the questions you've asked.
There are some incredibly well versed people on this site. There is a very deeply discussed thread regarding this antenna active right now. The purpose of the thread is to separate fact from fiction concerning this antenna, and to do that by exploring the science behind it. There are merchants who will sell you one and tell you the marketing pitch for it. Hang around until the analysis is done, or join the discussion, and you can read what is discovered. The quick answer can be Googled.
Homer
__________________
The 11 Meters MacGyver
  #4
Old 07-12-2010, 04:19 PM
Senior Member
hotrod is on a distinguished road
Default
welcome tp fourm
first checkout the maco 5/8 great alumin antenna at under 100. its a no brainer
second checkout the imax 2000 best fiberglass antenna EVER
these are the other 2 great performers with a nice price
__________________
BASE-magnum delta force, emperior 5010, AR 3500, sirio 2016
MOBILE-ss3900, uniden grant xl, z180, 636lS.E.
  #5
Old 07-12-2010, 09:30 PM
BOOTY MONSTER
Guest
Posts: n/a
Default
Modified Vector 4000
  #6
Old 07-13-2010, 05:03 AM
Jock Supporter
mackmobile43 is on a distinguished road
Default
Quote:
Forum searches are your friend.
  #7
Old 07-13-2010, 05:53 AM
Senior Member
Shockwave will become famous soon enough
Default
The Vector 4000 is the highest gain omni directional antenna being manufactured at this time. The antenna will however fall apart if you sneeze on it. Cover your mouth or turn away from the antenna. It's a shame because the antenna is a top performer. One can always replace the top sections with some real tubing since this is where they always break. The antenna design is controversial and created many false reports about it being no better then a half wave by those who do not understand it's operation.
While there are modifications that can improve it's performance it should be noted that the antenna works great right out of the box. The modifications that are being attempted would only improve performance slightly and at this point it still seems premature to determine the best way to modify the current design. It has been recently changed by Sirio and reflects the improvements people on this site have been claiming.
If signal strength outweighs durability for your application, the Vector is your choice. This is also one of the few antennas with enough bandwidth to cover both 10 and 11 meters without a tuner. The Maco V58 is the next best choice, then the Imax 2000. Personally, I'd buy the Vector, get rid of the ball on top and replace some of that weak aluminum tubing on top. Assemble and tune the antenna as per spec, then replace the weak junk on top. Adjust the top length to get the VSWR back to flat.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Difference between 2m and 70cm HT antennas? ke7vvt Amateur Radio Antennas 2 01-17-2010 04:33 PM
baluns towernewbie Amateur Radio Antennas 16 03-02-2008 04:11 AM
length of coax country boy jr CB Antennas 28 04-08-2006 08:03 AM
Frequencies Charger383 Scanning & Shortwave Listening 8 08-21-2001 06:44 PM
Powered by vBulletin®
