Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
imax 2000 with maco gpk kit or homebrew
Reply
  #1
Old 07-25-2010, 12:48 PM
Senior Member
1342 is on a distinguished road
Default imax 2000 with maco gpk kit or homebrew
has anyone tried this or like this picture!
  #2
Old 07-25-2010, 12:52 PM
Senior Member
hotrod is on a distinguished road
Default
Quote:
i auctually thought about doing this exact same thing. if this is yours
please keep me updated
__________________
BASE-magnum delta force, emperior 5010, AR 3500, sirio 2016
MOBILE-ss3900, uniden grant xl, z180, 636lS.E.
  #3
Old 07-25-2010, 03:25 PM
Marconi's Avatar
Supporting Member
Marconi is on a distinguished road
Default
That doesn't look like an Imax to me. It looks more like a Hygain type mult-element vertical. Maybe you are just referring to the Maco GPK.
No I have not tried one. What size mast does it fit and does it come with radials? If so, how long are they?
__________________
Marconi's YouTube Channel
We're just lucky that Mother Nature doesn't require our antenna systems to be perfect in order to work our radio.
  #4
Old 07-25-2010, 04:32 PM
BOOTY MONSTER
Guest
Posts: n/a
Default
id suggest reading this thread ......
To Ground Plane, or not to Ground Plane? That is the question...
and this thread ........
isolation from mast
  #5
Old 07-25-2010, 04:47 PM
BOOTY MONSTER
Guest
Posts: n/a
Default
Quote:
http://www.eagle1com.com/storepp/antennas/maco/GPRK.pdf
  #6
Old 07-25-2010, 05:22 PM
Senior Member
Default
this is more like a reference i have a imax 20 feet off my chimney with two sections of 10 ft mast and no ground.in the back yard i have a spare maco 5/8 with a hub and 4-10ft ground planes.i was thinking of setting the hub at the bottom by the feedline and i was not sure about whether i should isolate the antenna from the mast or not. thanks for those links booty i already read through all of those and nothing seems quite clear.i found a couple of posts on the net about people who have done this,one guy claimed he modified the bracket on the bottom and put 4 ground planes just under the tuning rings.the other guy with that picture claimed the same only he mounted them at the bottom by the feed like the picture.
  #7
Old 07-25-2010, 06:01 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
I would just mount it on the masting directly below the antenna feedpoint. Otherwise, the IMAX will just use the masting for the ground plane. That is the way I have mine set up - BTW - works fine and has a low SWR to boot...
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
  #8
Old 07-25-2010, 06:21 PM
Marconi's Avatar
Supporting Member
Default
I misspoke, thinking the image had anything at all specific to do with the question.
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
IMAX 2000 Ground Plane Kit... Robb CB Antennas 7 01-16-2012 01:45 AM
IMAX 2000 VERSES THE SOLARCON / ANTRON 99 TonyV225 CB Antennas 35 12-19-2011 10:29 PM
IMAX 2000 - Results w/GPK? Balun? Mast Isolation cominatyalive CB Antennas 39 12-13-2009 11:10 PM
Recommend Ground Plane Kit For Imax 2000? Wire Weasel CB Antennas 51 09-19-2009 06:16 PM
maco 5/9 vs IMAX 2000 "POLL" Porkchop454 CB Antennas 8 06-16-2008 05:01 PM
Powered by vBulletin®
