Hello homer BB,
I fully
am with your point of view in behavior of people.
And although im at least 8hrs a day busy with antennas if there is one thing i know is that i certainly do not know all...
So, guess you have many followers along with your point of view.
Reading through your post...trying to help lol... i only managed to find 1 question....
Perhaps there were more, but my lack of the langue migth be the problem.
quote; Ok, the point is that no matter where one is in their knowledge of what makes an antenna work, what we know is what we hear on our stations; more or less from our antenna. Or
am I wrong?
end of qoute.
Yes you are rigth....
If for your purpose the antenna does what it needs to do it is the best for sure.
The problem comes with two things:
At first the antenna will not do that all the time, you need to have a "known" starting point to wich we all can refer and often people are not willing to lisen to things like that...
The mind is set: "the antenna is louder at my neighbour...end of story."
For example there are a view videos of the sirio gainmaster in Europa with European sproadic E propagation. Everyone is impressed with the big signals etc...
But if you knew that sproadic depends on high angle TOA it would be so fancy anymore..
Secondly, often people start speaking about this is better etc in comparisment to that etc...Often antenna 1 is changed to antenna 2 but perhaps also the coax is renewed etc..
A 1/4 ground plane can outperform a 5/8 wave vertical for Dx...but does it have more gain...no...
So you need to get those things straigth...what are you searching for...
You need to have some background information some basic knowledge about antennas.
Secondly, i have actually constructed hundreds of antennas there isn't one who was different for theory. If theory says it cant be done....it can if not it wont work.
Surly it can happen that people without theory construct something that works...
But if that was the case it can be backed up by theory.
I have seen "respected" antenna manufacturers making many mistakes.
You can actually fill a day job getting into arguments on different forums.
Getting foolish arguments...
Not saying that i havnt or wont in the future (make mistakes)...but at least im pointing out as you are the willingness to make one.
What i
am confident that there are better ways to go to just change things and "hope" for the best...that not a efficient way....
The worse thing is you cant back anything up...the only thing you can mention..."it works great!" now, why believe that while everything can be explained.
Kind regards,
Henry
www.19sd348.nl
