Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
3 ele with Beta match home made....
Reply
  #1
Old 11-29-2010, 01:13 PM
Junior Member
zp9mce is on a distinguished road
Default 3 ele with Beta match home made....
Hi all, best regards from Paraguay
I wish them all a question I am building a 3 element yagi for cb, is a reform of an old antenna, using a beta match I had to make since it was broken.
Not adjust for the band, I leave the steps I am using for frequency 27555, 5.46 m reflector, driven director 5.25 and 5.02, the space between the reflector and driven is 1.50 m and between the director driven and 1.57 mts.
All measurements are in meters, the question is whether the measures seem right and how to make my beta match for this antenna.
Thanks for your help friends.
  #2
Old 11-29-2010, 01:23 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
One of the forum members ("Henry HPSD" from the Netherlands) has a great info page for what you seek:
11 meter DX sytems
Hope this helps!
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
  #3
Old 11-29-2010, 01:44 PM
Junior Member
Default
Quote:
11 meter DX sytems
Hope this helps!
Thank you for your prompt reply regarding the action of hairpin or beta match like me can help me, I read something in ARRL antenna book but still can not get the hainpin measures, if please some one designed for 11mts I appreciate your help.
73.
  #4
Old 11-29-2010, 02:10 PM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
This really takes some time to experiment and do a homebrew antenna build. I get way to frustrated but when there is great resources to reference to it sure makes things move a bit smoother.
I kinow we have som antenna gurus here on the forum that may also beable to help if they happen to chime in.
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #5
Old 11-30-2010, 12:46 AM
Senior Member
Henry HPSD is on a distinguished road
Default
Hi There,
If you provide the element thickness and lengths of the sections ill be more than happy to put the antenna in enzec and see what it does.
almost forgot...what is the maximum boomlength you can handle on that 3el ?
Henry
11 meter Dx antenna systemx
ps. tnx for the compliment, together with a m8, were working on a new site).
  #6
Old 11-30-2010, 01:15 AM
Marconi's Avatar
Supporting Member
Marconi is on a distinguished road
Default
zp9mce, I can't give you measurements. A lot depends of the diameters you are using. I would guess you might be a bit short in the # noted, but that will likely have to be trial and error. You might find some close approximations on the dimensions and the beta for 11 meter at:
http://www.cbtricks.com/ant_manuals/...ement_beam.pdf
This is for an old HyGain 5 element, but it may get you close. Take a look at the details in their manual.
Good luck and be careful.
__________________
Marconi's YouTube Channel
We're just lucky that Mother Nature doesn't require our antenna systems to be perfect in order to work our radio.
  #7
Old 11-30-2010, 04:59 AM
Crotchety Old Bastard
W5LZ is on a distinguished road
Default
Manuel,
I think the offer made by Henry is a good one.
There are several methods of 'feeding' an antenna, the Beta match is just one of them. I can't say if there would be any advantage to it, or not, I haven't dealt with them. Beta matches are not very common, probably because others are 'easier' ones to make and use.
Good luck!
  #8
Old 11-30-2010, 05:27 AM
Junior Member
Default
Hi to all. thanks fot the reponces.
I mention that the boom is 3 meters x 5 cm in diameter, the elements have a diameter of 2.5 cm and 2 cm at the ends.
The driven is cut and isolated from the rest of the antenna, just need to take measurements.
I have also prepared a coaxial choke with 1.22 meters of RG-58, 7 laps sore a pvc pipe unbalance the antenna.
I appreciate your help my friend, I commented that I have made a match of aluminum beta too but even I have no measurements.
73 from Paraguay.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Stock Maco gamma vs off-the-shelf beta match CHALLENGE! Master Chief CB Antennas 30 04-26-2012 04:09 PM
question about a home made antenna design BOOTY MONSTER CB Antennas 24 12-23-2009 01:10 AM
My first home made antenna wambulance Amateur Radio Antennas 4 10-12-2009 01:17 PM
Trying a home made yagi HomerBB CB Antennas 13 04-04-2009 06:26 AM
Home made antenna. King Mudduck CB Antennas 5 11-05-2005 05:37 PM
Powered by vBulletin®
