Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Who's got the best price on the I-Max 2000?
Reply
  #1
Old 12-07-2010, 06:28 PM
T23 T23 is offline
Senior Member
T23 is on a distinguished road
Default Who's got the best price on the I-Max 2000?
I am in the market for an I-Max 2000 antenna, who's got the best price for a new one? I thought I found an AD for one that said $80 shipped but I can't find it again.
T23
  #2
Old 12-07-2010, 06:38 PM
Jock Supporter
mackmobile43 is on a distinguished road
Default
GIJOE has it for 85 + 35 shipping.
  #3
Old 12-07-2010, 07:03 PM
BOOTY MONSTER
Guest
Posts: n/a
Default
why cant you use an antenna with ground elements ?
http://www.palcoelectronics.com/p1005081.aspx
http://www.cbradiomagazine.com/Anten...a%20Review.htm
  #4
Old 12-07-2010, 07:11 PM
T23 T23 is offline
Senior Member
Default
I see your point about ground elements BM, I am tight on space, and the reveiws are good on this antenna.
T23
  #5
Old 12-07-2010, 08:57 PM
Senior Member
Shockwave will become famous soon enough
Default
If you're under 500 watts, do yourself a favor and invest a few more dollars to purchase the Gain-Master from H&Y Electronics. The signal increase over the Imax is well worth the extra $45 and the appearance is very similar with no radials.
  #6
Old 12-07-2010, 09:22 PM
Marconi's Avatar
Supporting Member
Marconi is on a distinguished road
Default
Quote:
I would agree with SW even though I've not seen any reports comparing the Imax vs. SGM. But, to answer both BM and SW, maybe T23 wants the simplicity of the Imax. The only thing so simple and that really works well like the Imax is the A99 in my opinion. Under those circumstances I would not hesitate on the Solarcons.
My A99 works better than my Imax.
I may get it up to compare to my Gain Master and then I'll have more to say no mater how that turns out.
__________________
Marconi's YouTube Channel
We're just lucky that Mother Nature doesn't require our antenna systems to be perfect in order to work our radio.
  #7
Old 12-08-2010, 06:37 AM
T23 T23 is offline
Senior Member
Default
Great, thanks for the opinions, now I have some options, I'll look into these...
T23
  #8
Old 12-08-2010, 06:04 PM
radioreddz's Avatar
radioreddz is on a distinguished road
Default
i thought i was the only one that has a A99 that works better then an Imax. whats up with that Marconi i know you must have an explination with all the antenna testing you do. mine are 20' apart both have the feed point at the same height 38' both have 96' of belden 213 coax. i don't live in a valley i'm in a flat area so angle of radiation out of a hole don't count here. but in all directions ground wave the A99 out shots the Imax. also swr's on both on testing frequency 1.1 on ch. 35 testing on AM & 1.1 on ch.51 testing on Lsb. i thought maybe i had a faulty Imax. i think i'm gonna try the Gain Master i never run more then 300 watts and thats rare i talk 99.5% ssb so 300 watts is more then what i need to talk world wide.
__________________
doin it with class thru the glass.nuthin like the sweet smell & warm glow of the tubes it's like havin a new lady every day.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Airmail ops? Moleculo General Ham Radio Discussion 18 12-14-2011 05:42 PM
echo max 2000 radioman24 General CB Services Discussion 2 08-22-2010 01:38 AM
Astatic echo max 2000 4 pin plug radioman24 General CB Services Discussion 7 02-18-2010 06:36 PM
Powered by vBulletin®
