Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Capacitance Hat's Don't add Audio
Like Tree6Likes
Reply
  #185
Old 05-22-2011, 12:40 PM
Guest
MrSuburban is on a distinguished road
Default
Quote:
Originally Posted by Marconi View Post
76Q, here are some variations for radiator and top hat lengths for a 1/4 wave radiator. I used slanted down radials and one model that is full length and slanted down radials, and one model that is full 1/4 wavelength using 4 x 108" horizontal ss radials.
I also have a model of a simulated mobile, but I don't think the pattern is near what you might expect, so I didn't include it. I'm not even sure it is a good model. It shows to be workable however. I used the 4 horizontal radials and made 2 x 6" x 4' and 2 x 6" x 8'. I will work with it a bit and if it looks promising, I post it later. This may prove to be futile however, because mobiles have a very unpredictable ground plan with variations and curves that are irregular and may be difficult for me to model.
The numbers at the end of the captions are the length in inches for the radiator and the top hat including a little space for the feed point hub.
Attachment 4731
Eddie you have more segments in the cap hat than you do in the verical radiator. Try adding a bunch more segments in the vertical radiator
  #186
Old 05-22-2011, 12:41 PM
Guest
Default
Quote:
Originally Posted by BOOTY MONSTER View Post
anybody ever seen a top-hat on a commercial television or radio broadcasting antenna ?
i haven't , but i'm guessing the station and their advertisers want to reach every potential customer . if a top-hat will increased their broadcasting range or decrease the wind load and keep the same performance why wouldn't they use them ?
Yes they are common because they are using shortened verticals
  #187
Old 05-22-2011, 12:48 PM
BOOTY MONSTER
Guest
Posts: n/a
Default
first time i ever read/herd that cap hats only effect the rx and not the tx .
so cap'in kilo , in your use it was jut to shorten the antenna ? not for any supposed gain in tx ? from what i understand VLF , LF , HF and VHF react differently RF wise . so maybe maybe my question about commerical antennas was moot for HF/27 MHz. .
there's still a lot i don't know about antennas obviously . but as long as folks keep giving answers i'll keep having questions .
hehehe sooooo ...... is coilys audio ball a top hat or a corona ball ?
  #188
Old 05-22-2011, 01:13 PM
Marconi's Avatar
Supporting Member
Marconi is on a distinguished road
Default
Quote:
MrS, I have 7 segments in both. This was just a quick and dirty type of project. I started with a near 50/50 radiator to top hat model using 7 segments each and as I change the lengths, I just left the segments alone. It will make a little difference if I fixed the segments to the minimum per wire, but I didn't see enough difference to matter.
On a casual check MrS, it just doesn't seem to matter in this case. I'll check them all out though, and if I find one that does make the pattern, angle, gain, match, SWR, or reactance show a noticeable difference, I'll fix it.
Thanks for the tip.
__________________
Marconi's YouTube Channel
We're just lucky that Mother Nature doesn't require our antenna systems to be perfect in order to work our radio.
  #189
Old 05-22-2011, 01:20 PM
Marconi's Avatar
Supporting Member
Default
Being as they're rather small BM, I'd consider them mostly functional as a corona ball, a static or lightning supressor, but the main thing they do is keep folks from poking their eye.
__________________
  #190
Old 05-22-2011, 02:33 PM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt is on a distinguished road
Default
In my case it was not to shorten the antenna but rather because the antenna was short. A full size 1/4 wave on 1450 KHz is about 165 feet +/- so a 96 foot antenna is not much over 1/8 wavelength. At that frequency bandwidth is already hard to come by and even more so with a short antenna. Adding a cap hat allows a smaller coil at the base for matching which means lower losses and greater efficiency overall. The antenna gain persay does not increase but the efficiency does. I can't figure out what you mean when you said " from what I understand VLF , LF , HF and VHF react differently RF wise". AFAIK they all react the same regardless of frequency when it comes to antenna. The effect the ground beneath those antennas does change from VLF to VHF however,the former being extremely dependent on good ground conductivity while the latter pretty much cares less.
__________________
  #191
Old 05-22-2011, 11:06 PM
Guest
Default
Thanks for the tip.
I wouldnt add the minimum I would add more you will get a more accurate model i would beleive.
  #192
Old 03-11-2012, 03:04 PM
Default
Quote:
Originally Posted by BDOG-T7 View Post
I am developing a cap hat and may have it done by the end of the day. This will have an added feature of adjustability on the level of audio. Promise to make a world premiere here! The proof will be in the pudding. You will have no doubt in your mind that this can actually be done for sure.
Someone else needs to study a bit more on antenna and RF theory. A cap hat will not, in no way, ain't-going-to-happen-bullshit-if-it-is-claimed otherwise, going to effect the audio level of a transmitted or received signal. All the commercial broadcasters know that. All the RF engineers know that yet for some reason CB antenna manufacturers seem to know otherwise. Must be something real special about that Bubba's School of CB Tuning and Antenna making.
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
ICOM IC-2820 TX audio modification AudioShockwav Icom 0 05-23-2010 09:54 AM
ICOM IC 2200H Airband (AM) audio level modification AudioShockwav Icom 0 05-23-2010 09:38 AM
lincoln audio fault fodendaf General CB Services Discussion 6 05-11-2010 09:31 AM
Audio quality of 440mhz compared to 2m on HTs Moleculo HandiTalkies 9 02-01-2010 03:50 PM
Voodoo Audio 985chicago Station & Mobile Pics 36 11-26-2009 09:49 AM
Powered by vBulletin®
