Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Antennas
Amateur Callsign Lookup
Enter Callsign:
Mr.S here is my bandwidth curves for the Marconi 7x vs. 4x
Reply
  #1
Old 03-05-2011, 08:06 AM
Marconi's Avatar
Supporting Member
Marconi is on a distinguished road
Default Mr.S here is my bandwidth curves for the Marconi 7x vs. 4x
Hey MrS, I modified my Marconi antenna as you suggested, to see what happens with the 3 horizontal radials removed from the antenna. You didn't say, as usual, what you thought would be the results, when asking me what I thought those elements might be doing for the antenna.
When I did the first testing of my 1/4 wave idea, adding radials, I saw a nice increase in field strength on air and using my FS Meter at about 50' feet out and 20' feet high at the tip of the FSM antenna as I added more radials. I attempted to duplicate this idea back in 2009 again, but I was having trouble with my analyzer and failed in the attempt.
Here is what happened as best I can tell. I'll be testing the new M4x over the next few days to try and determine if I can see any difference against the SGM vs. the M7x. And then I'm going to try and test a shortened radiator with a top hat on the Marconi xx, which ever proves to show the best signals. It will be interesting to see what the bandwidth might show on such a setup as I suggest.
What do you think such a setup might show, including performance, match, and bandwidth?
Attachment 4265
Attachment 4266
Marconi 7x - 4x 030411.pdf
__________________
Marconi's YouTube Channel
We're just lucky that Mother Nature doesn't require our antenna systems to be perfect in order to work our radio.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Marconi comparing his Sigma4 vs. Marconi 7x Marconi CB Antennas 15 02-27-2011 06:40 PM
Marconi demonstrates checking bandwidth. Marconi CB Antennas 13 02-19-2011 04:56 PM
Does Cable Length Affect SWR? freecell CB Antennas 37 08-30-2004 03:21 PM
Powered by vBulletin®
