Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
Cobra 29 LTD no power
Reply
  #1
Old 04-23-2011, 08:13 PM
Junior Member
1998f150wes is on a distinguished road
Default Cobra 29 LTD no power
okay ive got all my wiring done right and want to know why when i plug my cb in nothing happens i tested power inside and out i read somewhere it could be this little dilode but i dont know where its at but anyways can anyone help me with this
  #2
Old 04-23-2011, 08:39 PM
Senior Member
cbradiomagazine.com is an unknown quantity at this point
Default
Did you check the fuse in the power cord?
Do you have a multimeter to verify you have power at the end if the power cord?
Instruction video on how to identify and replace the protection diode is on my website.
__________________
Visit my website - www.cbradiomagazine.com
  #3
Old 04-23-2011, 08:52 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
I think the schematic shows D23 is the protection diode. It is an 1N4003. If the radio keeps on poppin' fuses and won't turn on; that diode will need changing out.
A $.10 part - if that.
http://www.cbtricks.com/radios/cobra...ltd_sm_sch.pdf
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
  #4
Old 04-23-2011, 09:00 PM
Junior Member
Default
where is the D23 Dilode in the CB and where can i get the part
  #5
Old 04-23-2011, 09:10 PM
Robb's Avatar
Yup
Default
Quote:
Its a common diode. If there is a Radio Shack near you; they probably have it. There is a band/stripe on one end of this diode. The replacement diode has to be put in with that band turned/pointed the same way as the one you take out. It is near the power plug area of the radio.
__________________
  #6
Old 04-23-2011, 09:16 PM
359's Avatar
359 359 is online now
Senior Member
359 is on a distinguished road
Default
If you look around you might be able to find an instruction video on how to change it.
__________________
"Contradictions do not exist. Whenever you think that you are facing a contradiction, check your premises. You will find that one of them is wrong."
- Ayn Rand (1905-1982)
  #7
Old 04-23-2011, 09:22 PM
Junior Member
Default
im running a 5amp on my 29ltd will that blow the dilode cause before i was running a 30 amp
  #8
Old 04-23-2011, 10:42 PM
Robb's Avatar
Yup
Default
PROTECTION DIODE HOW TO TROUBLESHOOT A RADIO THAT WONT POWER ON
According to the schematic, the fuse required is a 12v/2 amp.
Fuses are in any piece of electrical equipment to prevent fires.
Abide by it . . .
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
