05-19-2011, 10:33 PM
 | Senior Member | | Join Date: Apr 2005 Location: Gilbert, Az.
Thanks for the input guys, I appreciate it! Quote:
Originally Posted by AudioShockwav Can you post what the radio alone is doing both dead key and modulated?
That will tell you drive going into the amp.
Jeff | Barely over 2 watts, swings to 15 Quote: |
Also, is this with "only" the red power button depressed?
| Red and Green on, as I understand the green "Dial a watt" button activates the variable output when it is on.
With the Amp on (Green and red on) it DK's 75, swings to 150
Red button only, DK's 140, swings to 175
FWIW, my Galaxy 44 just received Mosfet finals as an upgrade when I sent it in for a realignment... and had some cold solder repaired...
The readings were taken with a Dosy 3001...
