Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
President washington cB radio
Reply
  #1
Old 08-20-2011, 02:08 PM
Se7en's Avatar
Se7en is on a distinguished road
Default President washington cB radio
Just picked it up for $25.00
Replacing the meter light since its burnt out, with an led.
Haven't had a chance yet to use it waiting for a mate to bring a 5 pin mic. This one has rx and TX light. 3 push buttons mod, Chan 19(doesn't work) and another button forgot what it was. What pot is the modulation pot? Vr8? And also radio has ssb. Its almost minty. Cheers
posted using world wide Tapatalk. Droid DX
__________________
  #2
Old 08-20-2011, 02:19 PM
ExitThirteen's Avatar
Grumpy, Cranky Repairman
ExitThirteen is on a distinguished road
Default
That should have the MB8719 chassis in it if it's 3 button.
VR7 controls SSB output, Clip R104 or change R104 to a 100k ohm resistor to open up AM modulation.
The 3 buttons should be Mod/RF, NB/ANL, and Channel 9.
~Cheers~
__________________
Bases: Cobra 2000 GTL, President Washington, President Madison, Tram D201A
Mobiles: Cobra 146GTL, Midland 79-893 (NIB), Midland 13-893 (27.555), President P300
  #3
Old 08-20-2011, 02:25 PM
BOOTY MONSTER
Guest
Posts: n/a
Default
the board is the same as the cobra 142 gtl .
  #4
Old 08-20-2011, 02:52 PM
Se7en's Avatar
Default
hi, thanks. where is the deadkey pot? cant find it need to turn it down its 5w which is too high for my needs. ??? so which one does am and which one does am modulation?
says P400 on front of radio the channel 9 button doesnt work which im not concerned about,
__________________
  #5
Old 08-20-2011, 03:01 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
IF your Uniden Washington has the 8719 PLL chip in it; then:
VR1 Signal meter
VR2 Squelch
VR3 TX Frequency
VR5 Carrier balance
VR6 AM power
VR7 ALC
VR8 Driver Bias
VR9 Final Bias
VR10 RF power meter
VR12 Modulation meter
L1 Noise blanker
L2 Noise blanker
L3 I.F. 1st stage
L4 I.F. 2nd stage
L5 RX (6th stage)
L6 RX (5th stage)
L7 RX mixer output (4th stage)
L8 RX (3rd stage)
L9 RX (2nd stage)
L10 RX (1st stage)
L13 VCO
L14 VCO output
L17 AM offset frequency
L18 Loop mixer
L19 LSB loop frequency
L20 AM loop frequency
L26 TX mixer input
L27 TX mixer input
L28 TX mixer output (1st stage)
L29 TX (2nd stage)
L36 TX
L39 RFI low pass filter trap
CT1 USB offset frequency
CT2 LSB offset frequency
CT3 USB loop frequency
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
  #6
Old 08-20-2011, 03:23 PM
Se7en's Avatar
Default
ok just found out that the radio is transmitting between freqs??? im not sure what to do now?
__________________
  #7
Old 08-20-2011, 03:29 PM
Robb's Avatar
Yup
Default
Quote:
*Check to see if the clarifier is unlocked and has a lot of khz range/change.
*Look for a switch. Might be one of the panel switches.
*Might need alignment.
__________________
  #8
Old 08-20-2011, 05:26 PM
Se7en's Avatar
Default
ok on AM the clarify must be all the way to the right or im off freq. on ssb its very touchy and slides like 7 channels up and down needs a re alignment. so i figured it out the clarify does this, if im on 20 and need to go to 19A i just put the clarify at 12 o clock, need to go to 19 just all the way to the left.
channel 9 does not work...? and with the NB/ANL pushed in i cant transmit nor do i receive? weird part is inside it does not looked hacked or butchered up.
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
History of Citizen's Band Radio! KE3W General CB Services Discussion 20 07-04-2013 08:32 PM
Yaesu VX-8r Review Moleculo Product Reviews 250 06-22-2013 05:38 AM
How to choose your first Ham Radio pt. 2 Moleculo General Ham Radio Discussion 2 12-23-2009 02:25 PM
The ARRL Letter Vol. 27, No. 4 February 1, 2008 AudioShockwav FCC & ARRL Activity 0 02-01-2008 04:49 PM
Powered by vBulletin®
