Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
Fixing the Galaxy D88
Reply
  #17
Old 09-28-2011, 01:25 AM
Senior Member
RustDemon is on a distinguished road
Default
Been busy as hell with work recently 60-70+ hours a week.... recently caught a break and built the external case for the galaxy. vacuumed it out and plugged her in and hooked up my SWR meter. Everything seemed fine except figuring out where I wanted to be on all the settings. after a few minutes digging around in this rat-hole I call A brain I figured it out for normal cb operation.
I let it warm up on power for a few minutes to make sure nothing was going to puke from just being hooked up. after about 8 minutes I grabbed the mike and turned the squelch down. at 3 am here its not unusual to hear nothing but dead air on every channel, so I found channel 16 which is always dead so I wouldn't bug any one.. hit the transmit button and.....
it squealed briefly, pegged the needle, then started popping power surges about 1 per second. now the needle is stuck on 30db
on the bright side the freq counter seems to work..... and it will power up.
now to plan My next move... I think digging up a local cb shop may be a good idea. unfortunately I don't think there areany decent ones in this area outside of truck stops.
__________________
Nothing witty to say here. Would something half witty be acceptable?
KB1WLS
RCI-2950DX 10 - 12 meter, Pyramid ps-21kx power, Imax 2000 antenna on a 30 foot mast, rs SWR/powermeter. as my base unit. Cobra 148gtl on a wilson 5000 on mobile.
  #18
Old 09-28-2011, 03:20 AM
Senior Member
Default
I think I figured out my problem. the connex mic is wired different from the galaxy'e mic wiring. duh me. I just assumed they were all the same and plugged it in. so now I need to rewire a mic. or buy a new one for the galaxy.
__________________
KB1WLS
  #19
Old 09-28-2011, 03:45 AM
Senior Member
fnkycoldmedina is on a distinguished road
Default
connex and galaxy wire the same ,but the mic could have a problem either way .try a different one .or check the wiring
1-shield
2-audio-white
3-tx/red
4-ground/black
  #20
Old 09-28-2011, 03:41 PM
Senior Member
Default
well. I guess the website I looked at had the wrong wiring. I looked at some others and your right about the wiring. but the powermic works great on my connex. maybe I can't use a power mic on the galaxy. I'm going to have to look into that some more. thanks for pointing that out.
by the way I did wind up moving that frequency board back to its original position.
__________________
KB1WLS
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cobra 148GTL VS. Galaxy DX-949 CTStallion CB Band and CB Radios 51 08-20-2012 11:37 PM
Sounds Like FCC IS serious! More Busts! CW Morse FCC & ARRL Activity 40 03-15-2011 04:41 PM
Galaxy 95T2 Review Robb Export Radios 10 12-12-2009 03:52 PM
Powered by vBulletin®
