03-09-2012, 08:43 AM
| Junior Member | | Join Date: Feb 2012
Omega Magnum Quote:
Originally Posted by Super Briar I'm going to be buying a Magnum OmegaForce S-45 HP in the near future. Could someone recommend a reputable CB tech I could send it to who could properly "peak & tune" it, or better yet a place to buy one that could do the same. I would prefer the latter since it would kill two birds with one stone, but if not a heads up on a good quailty tech will suffice.
Second question...I only plan on using this radio on 11 meter, would this determine exactly how it should be tweeked, other than setting it up for 11 meter only operation (I know about that part & could do that myself if need be)?
Thank you,
SB | Tres bon radio,facile a utiliser sur le 11M |
