Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
cobra 29 variable power
Reply
  #1
Old 10-21-2012, 03:06 PM
Senior Member
9Lives is on a distinguished road
Default cobra 29 variable power
Hello everyone. I just did this mod on my older radio. The mod with the tip 120 transistor hooked to the rf gain pot. I know i did the mod correctly. But it's not working.. (so maybe i didn't look) it almost seems like it's not modulating. It's it possible the transformer is melted? Or is there anything people make Mistakes on while doing this mod?
  #2
Old 10-21-2012, 04:16 PM
RatsoW8's Avatar
Supporting Member
RatsoW8 is on a distinguished road
Default
Did you forget about this post?
Cobra 29 LTD Variable Power Mod
__________________
Closet Biker, CB'er and snooty Ham!!
20 wpm Extra
  #3
Old 10-24-2012, 06:11 AM
Junior Member
rockytopcummins is on a distinguished road
Default
Is this a hard mod to do? I hear it's very necessary if you're going to be running any additional power.
  #4
Old 10-24-2012, 05:08 PM
Senior Member
Default
If you can solder and de solder it's not hard. You also have to mount the transistor, which you can find on at radio shack. Pretty simple. I'm still debating if ilike out or not With the ekl
  #5
Old 10-25-2012, 12:28 AM
6string's Avatar
CB Lunatic
6string is on a distinguished road
Default
i have my rf gain wires soldered together i did the cbradiomag site trick i used a 470 uf cap and a 100 ohm res i get 0- 12 watt deadkey. very easy to set on RF gain var knob
__________________
  #6
Old 10-25-2012, 06:09 AM
Senior Member
The Jerk is an unknown quantity at this point
Default
Quote:
Not really...the dead key can be turned down to match the amp internally, the variable just makes it easier to do, but I find it also makes it easy to bump the power up and overdrive the amp if you not paying attention (read: don't have a meter in line).
My first Cobra 29 didn't have a variable, I just had the DK turned down and matched for the amp I was running...did the same for a Uniden Grant because I didn't want to hack it up to add a variable.
  #7
Old 10-25-2012, 02:25 PM
Senior Member
Default
When you say match the amp input, do you mean 3 watts or its there a way to figure what each amp needs? Mine is slamming my amp.
  #8
Old 10-25-2012, 03:44 PM
Senior Member
9C1Driver is on a distinguished road
Default
Quote:
Ouch, a 12 watt dead key? Most Cobra 29's work best with a variable range of say 1-6 watts. Whatever tech set that up for 12 watts on Hi did not know what he was doing.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
VARIABLE POWER W/ M 80 Modulator Swing Kit Built In ! Cobra 25 29 Uniden 76 78 Ebay CB Radio Gear eBay Auctions Ending Soon 0 06-06-2012 01:01 AM
VARIABLE POWER W/ M 80 Modulator Swing Kit Built In ! Cobra 25 29 Uniden 76 78 Ebay CB Radio Gear eBay Auctions Ending Soon 0 05-17-2012 09:10 PM
VARIABLE POWER W/ M 80 Modulator Swing Kit Built In ! Cobra 25 29 Uniden 76 78 Ebay CB Radio Gear eBay Auctions Ending Soon 0 03-26-2012 11:10 PM
Cobra 29 WX NW ST 40 Channel CB Radio w/ Swing Kit and Variable Power 25W!!!! Ebay CB Radio Gear eBay Auctions Ending Soon 0 02-14-2012 02:00 PM
Powered by vBulletin®
