Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
heat sink for rf ground?
Reply
  #1
Old 11-14-2012, 12:53 PM
Senior Member
9Lives is on a distinguished road
Default heat sink for rf ground?
The amp I'm building with the erf7530 s uses a solid copper board as the common ground. Right but it's feed backing like crazy so I'm going back through the circuit and doing soon tweaking. I read somewhere that i can use the heat sink for the rf ground and tie the source pins to it to help with feed back and oscillation. If i do this should i also tie the coax shield to the heat sink? If i do this do i need to tie it into dc ground with a capacitor, or will it be good enough for the source pins?
  #2
Old 11-15-2012, 05:47 AM
Senior Member
Default
Common, y'all help me with everything.. some body knows. If i use the heat sink as aground i need to tie it in to dc ground some where ?
  #3
Old 11-15-2012, 08:46 PM
Senior Member
Greatvalue1 is on a distinguished road
Default
The black wire, not the red one
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
the truth according to Firestik (get a drink and a snack , LOL) BOOTY MONSTER CB Antennas 14 04-20-2011 07:50 PM
Crackling 60hz hum three channels in a row, every 4th channel clear as a bell. cominatyalive CB Band and CB Radios 97 01-28-2011 04:31 AM
isolation from mast Splash1 CB Antennas 71 03-17-2010 09:23 PM
Grounding Straps thetnhillbilly CB Antennas 21 08-19-2009 10:18 AM
lighting and an imax King Mudduck CB Antennas 8 12-30-2005 03:56 PM
Powered by vBulletin®
