Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
Increase modulation on Cobra 25
Like Tree1Likes
Reply
  #1
Old 11-28-2013, 03:38 PM
Cheech's Avatar
Senior Member
Cheech is on a distinguished road
Default Increase modulation on Cobra 25
Anyway to further increase the modulation on Cobra 25 ltd classic without cutting the limiter or using a power mic? Ive got the VR maxed out.
__________________
CDX 825
Cobra 200GTL DX
Cobra 148GTL
Cobra 146GTL
Cobra 25
HR 2510
Texas Star 350
Jumbo 400
Yaesu FT 2800M
Motorola M1225
Hustler G7 150-1
Hustler G-2537 .64
Iota DLS-45/Optima D34
  #2
Old 11-28-2013, 04:50 PM
Senior Member
9C1Driver is on a distinguished road
Default
With out knowing what tune work has been done at some point the law of diminishing returns kicks in. If your at 100% things don't get better with 125 or 150% unless your talking about channel 6 audio quality. (or lack there of)
Maybe you could have a shop with a scope bench test it. Then it could be set at 100% and they could tell if say the VR5 pot was worn out or something else was keeping the radio from reaching the 100% mark. Beyond that if the radio is properly tuned and aligned and your at 100% modulation then the radio is being all it can be.
Edit: Cheech, I just saw your General Lee thread, it sounds like your skilled at some radio tech work. Maybe something has failed and is keeping VR5 from working as it should. There are some sharp members here, maybe they can chime in.
  #3
Old 11-28-2013, 05:05 PM
359's Avatar
359 359 is online now
Senior Member
359 is on a distinguished road
Default
Quote:
^^There is nothing true about that statement. Albeit there is nothing you can do with a Cobra 25 except remove/replace the modulation transformer, that's the bottleneck. The TIP120 mod just pinches the carrier off and keep alive mods still produce harmonics. That radio should sound fine at 100% modulation.
__________________
From milliwatts to kilowatts its all cool to me .... but life is to short for QRP !!
  #4
Old 11-28-2013, 07:06 PM
Senior Member
Default
Quote:
Hmmmm...ok. I think you agree with me that 100% is 100% and it should sound great there right? I have had many 25/29's that when you cranked VR5 wide open the audio quality went to he!! hence the term overmodulated. So then it would be true that 125 or 150% modulation does not sound good.
  #5
Old 11-28-2013, 07:20 PM
359's Avatar
Senior Member
Default
No, it sounds great when done with NPC or PPE. And honestly it sounds good on a Cobra which is running the negative to cutoff. Distortion in audio is desirable, such as compression, it's just a matter of controlling the harmonics as a byproduct.
__________________
  #6
Old 11-28-2013, 09:12 PM
Cheech's Avatar
Senior Member
Default
I'm only getting about 80% modulation with a whistle. The radio is stock otherwise.
I figured maybe something could be changed out to increase the modulation. I know 25s are capable of more than what this one is doing.
__________________
CDX 825
Cobra 200GTL DX
Cobra 148GTL
Cobra 146GTL
Cobra 25
HR 2510
Texas Star 350
Jumbo 400
Yaesu FT 2800M
Motorola M1225
Hustler G7 150-1
Hustler G-2537 .64
  #7
Old 11-28-2013, 11:12 PM
loosecannon's Avatar
break on through
loosecannon is on a distinguished road
Default
look on the solder side of the board for a resistor that is wired in parallel with VR5.
if there is one there, remove it.
you can also try changing C91 to a 33uF electrolytic cap.
this affects the AMC attack time.
__________________
https://i.chzbgr.com/maxW500/1912864512/h0491035C/
  #8
Old 11-29-2013, 08:12 AM
Senior Member
Default
I had a 2950 & Delta Force years ago that had the PPE mod. Always got great on air reports. His radio is stock I guess so there must be something going on.
359 likes this.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
COBRA 148 GTL Review Robb CB Band and CB Radios 47 11-12-2013 05:04 AM
Cobra 2000 gtl NO Modulation 3puttbob General CB Services Discussion 7 11-23-2012 05:35 AM
Cobra 148GTL VS. Galaxy DX-949 CTStallion CB Band and CB Radios 51 08-20-2012 11:37 PM
Uniden Pro 520xl modulation increase Hardhead CB Band and CB Radios 4 10-06-2006 06:10 AM
cobra 139 xlr modulation and wattage low cbman General CB Services Discussion 1 10-19-2004 08:58 PM
Powered by vBulletin®
