WorldWide Radio Forum
Go Back   WorldWide Radio Forum > Citizens Band Related > CB Band and CB Radios
Notices
All things CB. Discuss what you do with your CB as well as review and ask questions about AM & SSB CB radios.
Reply
  #1 (permalink)
Old 11-24-2004, 09:42 AM
NorthStar34
Guest
Posts: n/a
Default Re: Virage VX 68?
VX-38 AND VX-68 MOD
1.. FIND J28. MOVE JUMPER PINS FROM 1-2 TO 2-3.
2.. FIND J4. UNPLUG AND PLUG INTO J2
3.. ON THE BAND SELECTOR, THERE IS A WHITE, RED, AND BLACK WIRE. REMOVE
THE WHITE WIRE THAT IS SOLDERED TO THE RED WIRE AND SOLDER THE WHITE AND
BLACK WIRES TOGETHER.
4.. THE HI/LOW TONE SWITCH NOW BECOMES THE HI/LOW BAND SWITCH.
</p>
  #2 (permalink)
Old 11-25-2004, 01:31 PM
superduck62
Guest
Posts: n/a
Default Virage VX 68?
I need to know how to fully convert this radio to 11 meters. I have moved the 3 pin wire plug to the right socket in the front of the radio & moved the jumper over as needed. There is something else that still needs to be done. Radio has no resistor on top of board to remove as you would a Ranger 6300 or 6900. There has to be a wire that has to be moved. I need to know asap. Please do not respond unless you know exactly what i'm talking about. Thanks
superduck<img src=http://users.joplin.com/dutch64804/posticon60.gif ALT=":60">
</p>
  #3 (permalink)
Old 11-25-2004, 02:42 PM
NorthStar34
Guest
Posts: n/a
No Problem
</p>
  #4 (permalink)
Old 07-24-2008, 10:26 AM
Junior Member
Mixminister is on a distinguished road
Default
Thank you NorthStar34 post my Virage VX-68 now does 11 meter is their any other modification especially to the clarifier ? My peers says say I sound like crap when in ssb
Sincerely
Mixminister
Jamaica W.I
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
