You can change a rock in the radio, and drop it 2MHz or 4MHz if you want the 12 meter band. That would mean that when you are on 28.000.0 o0n the display, it will
TX/
RX on 26.000.0.The display will be off by 2MHz
It works, but I would spring for the ChipSwitch, it gives you a LOT of features for the work you would have to do/have done.
If you wanted to switch back and forth you would have to get the new rock(crystal) and build a small board to mount both on, with a few components to switch and tune it for proper frequencys on each band.
Or just swap the 22MHz rock out and re align the radio for one new band.
<span style="color:orange;font-family:helvetica;font-size:large;">RadioActive</span>
</p>
Edited by: <A HREF=http://p067.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=au dioshockwav>AudioShockwav</A> at: 3/23/05 5:47 pm
