Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
Realistic TRC-448 AM/SSB?
Like Tree1Likes
Reply
  #1
Old 04-21-2006, 10:33 PM
broncoman529's Avatar
Senior Member
broncoman529 is on a distinguished road
Default Realistic TRC-448 AM/SSB?
Does anyone have any information on this radio? What chassis is it built on? History? I picked one up and I cannot find much information about it. Does anyone have one? Do you like it? Please let me know.
Thanks,
__________________
Larry T. CDX529
" The Littlest Station In The Nation!"
  #2
Old 04-22-2006, 06:45 AM
Peddler's Avatar
SWR (sandwich with rum) Expert
Peddler is on a distinguished road
Default
Hope this helps;
REC86345
Models include:- Courier Blazer 40D/Renegade 40/Rogue 40/Nightrider 40DR/Ranger 40D, Fannon Fanfare 125F/182F/184F/185PLL/185DF/190F, Realistic TRC448
Uses simple 8 bit binary programming.
Easily modified by changing the loop mixing crystal.
__________________
  #3
Old 04-25-2006, 06:02 PM
Senior Member
bushwacker is on a distinguished road
Default
its a really good solid radio-- lots of power too with very little effort (for a cb)
you will be able to get some decent power out of it with just peaking it up-- cranks up real easy
Not much for actual mods for it... for extras go with what Peddler said-- thats the easest way
Its a good performer
__________________
Bushwacker-- Bush Station 588... VA3
Bench/ Communication Tech
Tridon Communications
  #4
Old 04-25-2006, 07:44 PM
AudioShockwav's Avatar
Extraterrestrial Admin
AudioShockwav has disabled reputation
Default
That is a great little Radio.
Bennie over at CBTricks has the VR`s here->
www.cbtricks.com/radios/realistic/trc_448/
Don`t let anyone talk you into cliping the AMC in that radio, just tweaking the VR`s and it is a BOOty SPaNking radio.
I am almost sure It used a couple of chunky transistors in push/pull in lue of the Audio IC that was in most of them at that time.
Smoking SSB for a single final/fcc cert rig.
1306 driver and a 1307 final...
There is a mod to open the clarifier for TX/RX
I have that info somewere ......
I will look around.
m42duster likes this.
__________________
Radio-active
http://sohowww.nascom.nasa.gov/data/realtime/eit_171/512/latest.jpg
NASA/SOHO
When I was a child
I caught a fleeting glimpse
Out of the corner of my eye.
I turned to look but it was gone
I cannot put my finger on it now
The child is grown,
The dream is gone.
but I have become comfortably numb.
  #5
Old 04-26-2006, 09:58 PM
Senior Member
Default
Sounds good, Any information would be great! Thanks for the info so far.
__________________
Larry T. CDX529
  #6
Old 05-04-2006, 09:40 PM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
I had good luck with my realistic radios only one out of the ones i owned that gave me any greif was the earlier trc-465
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #7
Old 05-05-2006, 05:04 PM
radioreddz's Avatar
radioreddz is on a distinguished road
Default 448 vs. 458
is there much difference between the trc 458 & trc 448
  #8
Old 05-07-2006, 09:47 PM
Senior Member
nomadradio is on a distinguished road
Default
BIG difference.
448 came from an entirely different vendor (factory). Pretty sure their name was "NDI", for Nihon Dengyo Inc", or something like that. That's the reason you've never seen that oddball PLL chip in any other radio. NDI wasn't the biggest supplier to USA name brands, but RatShack sold this one, made with the "Realistic" label stuck on the front and back. Parts can be hard to track down. Not many junkers out there to rob for parts.
The '458 is a Uniden product, likewise a "private label" source for RatShack way back then. The same main circuit board appeared in a handful of other brands/models from 1978/79. Has the big, fat "uPD-858" Pll chip, which is not "locked", and can be modded for added frequency coverage. The rest of what's inside is completely different from any NDI radio, but similar to the TRC-457, original President Madison and Washington, the ones with the 4-pin mike socket. President (then called American Radio) also sold a mobile version. The model name? Can't remember. Robyn SB-520D, Cobra 139XLR base radios were also made by Uniden, and had the same main circuit board.
The one heartbreaking weak spot is the tiny Omron MX-3P relay it uses to transfer from receive mode to transmit. A high-mileage radio may have a worn-out relay. Can't get them any more. A sharp horse-trader will know this, and may "harvest" the good relay from a low-mileage radio, putting a worn-out one in before he sells the thing. Look to see if the wire retaining spring is still snapped over the relay. If not, someone could have changed the relay, or removed it to try cleaning the contact points. Seldom helps. Once the thin electroplated layer on those tiny points wears off, no amount of cleaning will make it work for more than a week at a time. A "lost" retaining spring at least tells you someone messed with the relay (for whatever reason), and lost the thing.
The noise blanker is pretty good in these, if it's adjusted right. Tends to bleed from strong nearby stations worse than the blanker found in newer Uniden radios that have the MB8734/8719 PLL chip. Still better than no blanker at all.
__________________
These are not the 'droids you've been looking for.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/cb-band-cb-radios/23179-realistic-trc-448-am-ssb.html
Posted By For Type Date Hits
The Defpom Forum, for RadioMods, S&M Software and Music by The Defpom View topic - ndi pc-201 This thread Refback 09-03-2009 07:08 AM 22
Powered by vBulletin®
