Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
Galaxy 99
Reply
  #1
Old 06-04-2007, 06:52 AM
AE5RD's Avatar
Reformed CB'er
AE5RD is on a distinguished road
Default Galaxy 99
Can anything be done for the Galaxy 99's transmit tone and quality on SSB? I get reports of a high pitched audio with no lows. I have tried several mics. Also the radio seems to be hard to tune right on and drifts. I remember someone posting about some agc circuit modifications. The 99 transmits great on AM, but i want it to be usable on SSB.
  #2
Old 06-09-2007, 08:30 AM
King Mudduck's Avatar
FEAR THE DUCK!
King Mudduck is an unknown quantity at this point
Default
Maybe you should good to cbtricks.com and look up the Galaxy 99 in the radios section, you can find all the info you need. Make sure the driver bias and the final bias are set correctly if not it could cause you to sound funky on ssb.
.......your modulation limiter has not been clipped has it?
__________________
Government = Massive spending, Higher taxes and Shredding the Constitution!
When will enough be enough?
  #3
Old 06-09-2007, 01:18 PM
Senior Member
lords is on a distinguished road
Default Re: Galaxy 99
Quote:
what mics have your tryed?
The radios come complete with low-impedance (500 ohm) dynamic
microphone.
I worked on a 88 same inters and have used a Galaxy stock mic and a D104 minute man2 on it without a problem...
__________________
Cobra-90LTD 8 swinging 35 Noclip
Cobra 148GTL
Cobra 148F(EXPORT)
Cobra 200GTL
Mod V-Plus
Homemade 8 pill running 18 volts
Brute force 350
Maco V5000
Spitfire 427 3 element beam
  #4
Old 06-09-2007, 11:17 PM
TonyV225's Avatar
TonyV225 is on a distinguished road
Default
If your a SSB user then my advice is run run very far away from that thing the odds of getting one that doesnt warble are slim eventhough they are out there
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #5
Old 06-12-2007, 02:56 PM
Galaxy Tech
GRTS is on a distinguished road
This typically happens when tweak shops cut the ALC or some mod shop has put in their Super Secret Mega Whooper.
Now your SSB audio sounds like crap but hey, your blowing smoke with that excessive flat-topping over distorted AM audio.
8)
  #6
Old 06-12-2007, 03:01 PM
Senior Member
NorthStar has disabled reputation
Default
Only way to go.
  #7
Old 06-13-2007, 11:49 PM
AE5RD's Avatar
Reformed CB'er
Default Galaxy 99
I reinstalled the tr53 limiter and i have used the stock mike and a road king 56, an astatic noise cancelling mike, a barjan mike, an sbe mike, and several others. I do tear it up on AM and that's the only mode the 99 is good for. My Cobra 142 GTL works great on ssb and AM. Anyways I got my general ticket so I will be using my HF rig more than my CB rigs.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
