Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
galaxy saturn base VR's
Reply
  #1
Old 08-26-2007, 06:02 PM
Registered User
FL Native is on a distinguished road
Default galaxy saturn base VR's
power tuning pots for high and low power AM and SSB and modulation. thanks in advance.
only seeing about 10 watts carrier and max 20 swing.
(on high setting)
i thought this radio would do a little more than this ?
  #2
Old 08-30-2007, 02:43 AM
Senior Member
hotrod is on a distinguished road
Default
that sounds pretty close actually.10watt dk is max
for that radio and 25-30 watt pep.and 25-30 pep on ssb
thats all they do.with clean audio
__________________
BASE-emperior 5010,sirio 2016
MOBILE-ss3900,sirioz180,astatic 636SE
  #3
Old 08-31-2007, 06:52 PM
Senior Member
DTB Radio is on a distinguished road
Default
depending on the condition of the finals and driver, I would expect between 35 and 40 out of that radio. If its an older radio with all original parts, then 25-30 is a fair expectation. If it is only doing 20 peak, then set the key for about 5 watts. (4:1 ratio)
__________________
73's as always!
SHOP AT DTBRADIO.COM'S ONLINE STORE
Use this email address to contact me.
  #4
Old 09-02-2007, 07:16 AM
Senior Member
Default
orignal galaxy saturan [not 2517 version]
vr14-modulation set to max or a tad under
vr13-am high dk-i set to 8 but no more than 10 watts
vr16-am low dk-2 watts
vr12-ssb alc iset mine generally 3/4 ways up.ssb warble may
start if ya max it out.i wouldnt max this out.also i do this
on cb ch.20 seem to balance out power.use a dummy load
also if ya have one,if not i ould get one thier inexpensive
and work great.
__________________
  #5
Old 09-02-2007, 04:20 PM
Registered User
Default
na it not on the board this one is old.and is just loaner from a friend.
must have had to many screw drivers in it. the low rf power wont ajust. LOL make my 8 pill cadillac along at 100 swinging 300.
will be sending the 2995dx off to ranger probly next week.
it only lasted 2 weeks after the lightening hit. then it let out the smoke.
  #6
Old 09-03-2007, 11:41 AM
Senior Member
Default
this is the old galaxy saturn right?
or is it a galaxy 11b which if i remember right both look same
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
