Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
delta tune
Like Tree1Likes
Reply
  #1
Old 09-11-2007, 01:05 PM
bigred222's Avatar
Key Up City Radio
bigred222 is on a distinguished road
Default delta tune
What the heck is delta tune. I just picked up a virgin 29xlr with it and i have no idea what it is. any ideas on what i could do to make the 29xlr a little more awseome.
__________________
Galaxy 95T/146GTL/Wilson1k/A99 40ft to base ele 375ft
  #2
Old 09-11-2007, 01:23 PM
Senior Member
SR385 is on a distinguished road
Default
Clarifier for SSB use. It trims up the received signal to dial it in.
At least that is what it was on an old Pace I used to have.
  #3
Old 09-11-2007, 01:25 PM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt will become famous soon enough
Default
The word "delta" actually means "changing". In other words it is just a fancy name for a receiver clarifer or fine tuning.
  #4
Old 09-11-2007, 02:14 PM
Guest
Master Chief is an unknown quantity at this point
Default
The 29 is an AM radio only. It has a delta tune. SSB radios have a clarifier of some sort, not a delta tune.
  #5
Old 09-11-2007, 02:38 PM
Senior Member
BIONIC_TEXAN88 is on a distinguished road
Default
the delta tune is kinda like a clarifier, but a very slight difference is noticed on am.
  #6
Old 09-11-2007, 06:41 PM
bigred222's Avatar
Key Up City Radio
Default
yeah thats what i thought it was and i turned it while i was testing it and it wasnt doing anything so i just deemed it useless and unimportant. thanks guys
73's
__________________
  #7
Old 09-11-2007, 08:27 PM
loosecannon's Avatar
break on through
loosecannon is on a distinguished road
Default
the delta tune is a useless feature that the manufacturer included for the specific purpose of having an easily accessible location for things like echo controls, variable power, or a channel switch.
thats just what i think.
who knows what the actual reason was for putting a "clarifier" on an AM radio.
loosecannon
__________________
https://i.chzbgr.com/maxW500/1912864512/h0491035C/
  #8
Old 09-12-2007, 06:07 AM
Supporting Member
CollinsMan is on a distinguished road
Default
My Uniden PC 78XL has delta tune, and I modified it to slide between the standard CB channels. It will swing down about 11 KC and up about 2 KC from the center detent position.
I modified the radio with an external oscillator to work on 29 MHz for Ham AM use, and the delta tune mod really helps me tune in the guys who don't use the "5s." On the actual CB band, this ability probably wouldn't be needed because of simpler ways to get on the "A" channels. (Capacitor-10.240-Switch Method)
I think that the original reason for having delta tune on the AM only CBs was so you could tune in folks whose old 23 channel "crystal-plexers" had drifted WAY off frequency. However, as Loosecannon said, now it is mostly used to put echo, etc. in the place of...
AA1QD likes this.
__________________
CollinsMan
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
