Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
Galaxy 2547 getting hung up
Reply
  #1
Old 09-17-2007, 08:27 AM
Key Up City Radio
bigred222 is on a distinguished road
Default Galaxy 2547 getting hung up
Sometimes my galaxy is getting hung up. what i mean by that
Key the mic no recieve = normal
Unkey the mic, transmit light goes back to green
linear unkeys
Still no Recieve audio.
key the mic on and off 1 or 2 times. Audio comes back.
Or let it sit for about 30 seconds audio SLOOWWWLLY comes back.
WHats the deal guys.
__________________
Galaxy DX2547
Antron 99
Cobra 29xlr
Cobra 21Ltd Switch kit special
ADX-202
CDX-202
WWW.CBJUNK.COM Come here for fine CB Chatter
Worldwide Radio Forum
  #2
Old 09-17-2007, 09:37 AM
Switch Kit's Avatar
Senior Member
Switch Kit is an unknown quantity at this point
Default
try the radio without amp in line ? check your radio controls ? I never heard of a relay opening and closing slowly like that ?
  #3
Old 09-17-2007, 10:48 AM
Junior Member
sonoma is on a distinguished road
Default
I have seen a mic do this if the spring in the switch gets weak.verify your mic is good.
  #4
Old 09-17-2007, 12:28 PM
Space Cadet is on a distinguished road
Default
I've seen this happen on many galaxy radios, the culprit has always been a cold solder joint. If problem occurs without amp in line, then I would look closely at the solder side of the board.
  #5
Old 09-17-2007, 05:34 PM
Key Up City Radio
Default
Quote:
yes it does it with the amp out of line
__________________
Galaxy DX2547
Antron 99
Cobra 29xlr
ADX-202
CDX-202
  #6
Old 09-17-2007, 05:35 PM
Key Up City Radio
Default
Quote:
If i disconnect the mike it stays keyed
__________________
Galaxy DX2547
Antron 99
Cobra 29xlr
ADX-202
CDX-202
  #7
Old 09-17-2007, 05:37 PM
Key Up City Radio
Default
Quote:
any ideas where to look for the cold joint??
__________________
Galaxy DX2547
Antron 99
Cobra 29xlr
ADX-202
CDX-202
  #8
Old 09-17-2007, 08:22 PM
TonyV225's Avatar
Senior Member
TonyV225 is on a distinguished road
Default
Also check the mic jack inside the radio where the wires connect to the 4 pins. reheat the solder on the wires one by one and make sure nothing is touchiing or shorting all it takes is one hair sized piece of wire to short to points together.
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
  #9
Old 09-17-2007, 10:31 PM
Default
One question... Does the s/rf meter show the signal being steady and present, or can you see it "fade in" on the meter... It's kind of hard to say exactly where to look, but... (assuming needle shows the "fade in", and most likely)...
I would start near the center of the rear chassis (by where the connection comes from the so-239). With the radio solder side up, and knobs facing towards you, work your way around the board, clockwise. Pay special attention in the area of the PLL/VCO section. You should be able to find a spot you can fidget with that makes the rx come right back. Most of the action you are interested in is occurring in this region (uhhm....top and bottom right quadrants of radio...if that makes any sense). A little skillful poking, a little prayer, and a lot of luck might make it easy. Sometimes cold solder joints can be a b!tc#.
If your s/rf meter shows the signal being present at all times, then look on the left side of the radio (still solder side up, knobs to the front), as this is where most components in the audio section are located.
  #10
Old 09-18-2007, 07:35 AM
Key Up City Radio
Default
when it stays keyed the signal meter goes back to where it should. unless someone else keys up then it moves.
__________________
Galaxy DX2547
Antron 99
Cobra 29xlr
ADX-202
CDX-202
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
