Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
Uniden's DSC Dynamic Squelch Control
Reply
  #1
Old 10-09-2007, 12:55 PM
Senior Member
Chainsawgang is on a distinguished road
Default Uniden's DSC Dynamic Squelch Control
I have 2 or three Unidens with the DSC ( which is NOT supposed to be like SoundTracker) . What do you guys think of it. I have tried it several times but, it seems I pick up bits & pieces of conversations . I have been trying the DSC but, haven't been too pleased with it so far . Any of you guys here have any thoughts?
__________________
Hey Driver !, YA got a COPY ??? c'mon back
  #2
Old 10-09-2007, 01:45 PM
AudioShockwav's Avatar
Extraterrestrial Admin
AudioShockwav has disabled reputation
Default
DSC is basically a pre-set Squelch Level, this was called Auto Squelch on the Lincoln, 2510 and 2600. If you want better control, just adjust the Squelch knob by hand to the level were you want it. About the only time I have found it useful is when using FM mode, just click it on and go to FM.
__________________
Radio-active
NASA/SOHO
there is no dark side in the moon, really. As a matter of fact it's all dark
  #3
Old 10-09-2007, 02:23 PM
Senior Member
Default
Quote:
Good Point Jeff !
I agree with you , the normal squelch does work better for that type of usage. I'll try that DSC on FM. THX
__________________
  #4
Old 10-09-2007, 02:44 PM
Senior Member
BIONIC_TEXAN88 is on a distinguished road
Default
the DSC works good if you are running with someone thats fairly close.
  #5
Old 10-09-2007, 05:22 PM
74IN's Avatar
Senior Member
74IN is on a distinguished road
Default
Useless, all the ones I had with that, I used the switch for talkback.
  #6
Old 10-10-2007, 06:05 AM
bigred222's Avatar
Key Up City Radio
bigred222 is on a distinguished road
Default
Quote:
yep, but otherwise like 74in its good for a talkback switch or whatever else you would use it for. I used it for the switch for lights i had on a pc68xl i had.
__________________
Mobile 95T/Wilson 1k Mag/4 Mrf 455's
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
