Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
GALAXY MELAKA
Like Tree1Likes
Reply
  #1
Old 11-29-2007, 12:58 PM
bigred222's Avatar
Key Up City Radio
bigred222 is on a distinguished road
Default GALAXY MELAKA
OK BOYS WHATS THE LOWDOWN on this radio that i got comming in the mail?
Info
CB tricks Had NADA on it so I figured id check here as always.
If you can get the info for me id love to know the following.
Frequency range
Power Output
Mic connector
What board it has
What Mods i can do to it.
__________________
Galaxy 95T/146GTL/Wilson1k/A99 40ft to base ele 375ft
  #2
Old 11-29-2007, 01:32 PM
Carl's Avatar
Technologicaly Challenged
Carl is on a distinguished road
Default
ahh the good old melaka. it was the son of the old galaxy ssb. it was the cheapest galaxy base at the time. they were about $189 new from copper electronics. back in the late 90's. thwy could be expanded for extras but you needed to unlock the clairifer to get 10k of slide for able's. once you did this ssb because useless. ive seen a few with cracked mainboards, why i dont know.
they get pretty loud (and splattery). ssb was nothing to write home about, they had a signal meter meter and a "on air" light instead of a second meter. uses 1969 final with peak around 20 watts.
adjustments
modulation vr-14
am power vr-13
alc vr-12
VR 1 ~ AM/FM S-Meter
VR 2 ~ SSB S-Meter
VR 3 ~ SSB Squelch Range
VR 4 ~ AM/FM Squelch Range
VR 5 ~ FM Deviation
VR 7 ~ SSB Carrier Balance
VR 8 ~ RF Meter
VR10 ~ Final Bias
VR11 ~ Driver Bias
VR20 ~ Final Bias
VR21 ~ TX Offset
TALK BACK MODIFICATION:
To add Talkback to your Galaxy Melaka , Locate D-80 inside the radio near the Audio Transformer. Cut one end of D-80.
conversion
#1 ~ Remove the Top and Bottom Cover's.
#2 ~ Notice on the Bottom side of the main board towards the Front there is a small Jumper wire soldered to the board. One end of the wire is soldered to Ground and the other end is soldered across 2 pins. Remove this wire and at the same time make sure that the 2 pins are no longer shorted together.
#3 ~ Re-install the Top & Bottom Cover's.
__________________
NĜAAT
  #3
Old 11-29-2007, 01:39 PM
bigred222's Avatar
Key Up City Radio
Default
THANKS CARL. How Bad is the SSB because im a big ssb guy.
__________________
  #4
Old 11-29-2007, 01:48 PM
bigred222's Avatar
Key Up City Radio
Default
do they make frequency counters that plug into that jack on the back. And do you know what band is the standard CB band?
__________________
  #5
Old 11-29-2007, 02:13 PM
Carl's Avatar
Default
ya there is a female jack in the back for a freq counter. if i rember correctly band c is standard cb frequencys. ssb works as long as you keep the limiter in place and dont unlock the clairifer for the 10k adjustment. its not the best as with any export radio but it works, i would use one of the hf rigs you have there for ssb use, especially if you have a filter installed.
__________________
NĜAAT
  #6
Old 11-29-2007, 07:17 PM
Switch Kit's Avatar
Senior Member
Switch Kit is an unknown quantity at this point
Default
In 1995 I traded a Sony 2010 Shortwave radio (I have missed that Sony now for 12 long years :cry: ) for a Melaka base. I totally hated that base from the day I traded for it !! Audio sucked on both AM/SSB and receive seemed fair at most. In my parts there was basically a big strapper on channel six who went by Superfly out of Pomona Cal. Very nice old man as well , I still hear him from time to time but he is nothing like he once was in the 80s and early 90s . I traded him the base for a first run 148GTL ! in many minds they felt I had traded down ! Far as I was concerned , I traded up big time ! Not only that , I kind of felt cb warm and fuzzy that I now owned a Superfly 148 GTL . To Red ........maybe one day you can treat yourself to a older 148 or even a Grant XL , the audio and receive are one of a kind on those radios where cb is concerned. Peace
  #7
Old 11-30-2007, 04:46 AM
bigred222's Avatar
Key Up City Radio
Default
well i hope i didnt just waste 160 bucks. I seem to have good luck with radios though. maybe ill get lucky and get a good one.
__________________
  #8
Old 12-05-2007, 10:24 AM
bigred222's Avatar
Key Up City Radio
Default
how do i unlock the clarifier???
__________________
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
