Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
Swing /Modulation
Reply
  #21
Old 03-02-2008, 07:56 PM
Starduster is on a distinguished road
Default
Quote:
Originally Posted by hotrod View Post
cool let us how ya do
Well I was able to find a test today in a nearby town so I went for it.
Now I have my General class ticket. If any one is interested in getting your Ham ticket, check out http://www.hamtestonline.com After a few hours of study using the method on that web site you should be ready. It is the best method that I seen. So it cost 50 bucks, but it works. I tried for the Extra class ticket because it was free if you passed the Tech and General test but i didn't study for that one so no luck. If I would have known that it was also free I would have studied for that one also. I'll have to go for it after some study. They get tougher as you go.
Always wanted a Ham ticket. No regrets. Can't wait to see what my call sighn willl be.
JUST DO IT, YOU CAN
Starduster
Worldwide Radio Forum
  #22
Old 03-03-2008, 01:12 PM
Geekster's Avatar
Senior Member
Geekster is on a distinguished road
Default
Welcome aboard the forum and to the hobby!
__________________
I geek therefore I am...
I geeked therefore I were...
"Fides Quaerens Intellectum"
  #23
Old 03-05-2008, 05:14 AM
psycho's Avatar
Senior Member
psycho is an unknown quantity at this point
Default
Quote:
Originally Posted by W5LZ View Post
'Swing' is sort of the uninformed way of saying percentages of modulation. And, since "more is always better" to those who don't really understand what modulation is and why it's done, the more 'swing' the more better. I mean, if that needle 'swings' further then it's gotta be stronger, right? Right?
Yeah, I know, I know. But how do you convince someone that what they 'know' isn't the way it really is? Don't bother, it's a waste of time...
Do you have a serious problem with the human race?
  #24
Old 03-05-2008, 09:46 AM
BANNED
freecell is an unknown quantity at this point
Default
"Just what is ment by swing?"
the proper terminology is modulation index or modulation percentage. the term/s is/are used to describe the ratio between the maximum and minimum voltages present in a modulated signal referenced to the resting unmodulated carrier.
the method of power measurement must be taken into account here if the results are to provide an accurate representation of the resulting power relationships. the two most often used measurement methods are PEP and AVG.. an asymmetrically modulated signal representative of a modulation index of 1 (100%) exists when in the case of AVG. power the modulated power output is approximately 1.5 times the resting unmodulated carrier and in the case of PEP when modulated power output is 4 times the resting unmodulated carrier.
these facts are mathematically supported and are not open to interpretation.
i won't bore you with the algebraic equations unless requested or you can view them here.
http://www.firecommunications.com/hlsos.html
  #25
Old 03-05-2008, 04:16 PM
Geekster's Avatar
Senior Member
Default
Swing?
Well:
*Ohio is considered a swing state
*Swings can be found on a front porch
*Swing could be referred to as a 1930's Jazz style of music
And of course...
__________________
Reply
Bookmarks
Tags
am modulation
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.1
