Go Back   WorldwideDX Amateur Radio Forums > Citizens Band Related > CB Band and CB Radios
Amateur Callsign Lookup
Enter Callsign:
Cobra 2000 GTL Mods
Reply
  #9
Old 03-28-2008, 07:36 PM
Senior Member
DJboutit is on a distinguished road
Default
555 you can do the 25 dk & swing to 200 how much would that cost would it be done right so the radio is not dead in 2 years from heavy use. If you can do that I will give you a glaxy hd 250 amp
__________________
[URL="http://radiopirates.18.forumer.com"]
  #10
Old 03-29-2008, 08:50 PM
Junior Member
tony950 is on a distinguished road
Default
dj your best bet is to have the radio adjusted corectly . dead key turned down to 1 or 2 watts and swing to max , and just put it behind a good mobile or base amp behind it
  #11
Old 03-29-2008, 08:56 PM
555 555 is offline
Senior Member
555 is on a distinguished road
Default
Quote:
then why not have a varaible power knob installed turned all the way down it will deadkey 1/2 watt
into your galaxy 250 then it will keyaround 15 to 25 watts and swing close to 150 to 180 watts
  #12
Old 03-29-2008, 10:52 PM
Senior Member
Default
I have a power knob on the radio already
__________________
  #13
Old 03-30-2008, 08:37 PM
Guest
Master Chief is an unknown quantity at this point
Default
The radio has already been butchered. Dave and 555 are right. It kills me to once again witness the CB mentality at work.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
