WorldWide Radio Forum
Go Back   WorldWide Radio Forum > Citizens Band Related > CB Band and CB Radios
Notices
All things CB. Discuss what you do with your CB as well as review and ask questions about AM & SSB CB radios.
Reply
  #1 (permalink)
Old 09-06-2008, 04:56 PM
Junior Member
Big Dog is on a distinguished road
Default Galaxy DX99V
Hi, Im new to this forum and Im not too educated about CB radios, I just got this radio used and Id apreciate your opinions and/or comments about it. Great forum, Thanks Lou
  #2 (permalink)
Old 09-06-2008, 05:06 PM
pro151's Avatar
pro151 is on a distinguished road
Default
Oh boy, thats bad. I hope you did not pay to much for it, it is a piece of junk and I will take it off of your hands so you won't have to suffer with it.
Just ship it to me pre-paid and include a $20.00 bill in the package for my trouble.
I like all of the Galaxy radios and the 99V is a good unit with several good mods available to turn it loose.
If it has not been hacked up on the inside, it will make a good radio for you.
__________________
Radio. The Original Wireless Communication.
Excellence is Expected.
Perfection will be Tolerated.
We must all Agree to Disagree Agreeably.
Outlaw 151, North Alabama.
http://s236.photobucket.com/albums/f...RO151%20Shack/
  #3 (permalink)
Old 09-07-2008, 03:51 PM
poorman's Avatar
Junior Member
poorman is on a distinguished road
Default
Probably my all time favorite radio. There are a lot of things that be done to make it a screamer.....
  #4 (permalink)
Old 09-07-2008, 07:05 PM
Junior Member
Default
I have a 250 watt Boomer amp hooked to it but Im getting high SWRs, Im hoping its the old ant. wire.
  #5 (permalink)
Old 09-07-2008, 10:28 PM
Senior Member
loosecannon is an unknown quantity at this point
Default
first,
make sure you are checking the SWR the proper way.
do a google search for "how to check your SWR" or something like that,
and you should find a few tutorials to make sure you are doing it right.
if you are doing it right, and still having high SWR, then check these things:
amp and radio power and ground need to be run right to the pos and neg terminals of the battery.
antenna needs to be a good one capable of handling the power, and needs to be mounted properly in the right location. (reply and give us all the details about your antenna system. include all the things you dont think you need to)
the 99v needs to have the RF power set to a 2 watt deadkey to work with that amp.
there should be a knob on the front of the radio to set this with.
with the radio's meter set to read the RF output, key the mic, and turn this knob down until the meter shows 2 watts out.
the more details you give us about your installation the more we can help you.
later,
__________________
well yeah, but what's really going on?
  #6 (permalink)
Old 09-08-2008, 04:57 AM
pro151's Avatar
Default
Check here for usefull information.
Wilson Antenna Tech support - Index to Technical Support
__________________
  #7 (permalink)
Old 09-08-2008, 06:57 AM
Senior Member
formulamojo is an unknown quantity at this point
Default
Quote:
Originally Posted by loosecannon View Post
first,
later,
I agree with all of that except the part about the negative from the amp going to the battery.
When running amps you want to keep the grounds as short as possible. The longer a ground the more RF interference you are inviting.
__________________
MoJo
www.mojoenterprises.us
  #8 (permalink)
Old 09-08-2008, 08:31 AM
Beetle's Avatar
Senior Member
Beetle is on a distinguished road
Default
Quote:
If you're not using an external meter and you're relying on the meter in the radio, there are two possibilities:
#1: The meter's wrong. A lot of built-in meters are.
#2: The input circuitry of the amplifier doesn't present a 50-ohm impedance to the radio. This is a defect in the amplifier, not the radio.
That said, are you using an external SWR meter?
If so, is the meter immediately after the radio, or immediately after the amplifier?
__________________
No trees were harmed in the sending of this post; however, many electrons were inconvenienced.
73 de K7KBN
  #9 (permalink)
Old 09-08-2008, 08:09 PM
Senior Member
Default
formulamojo,
im not sure i understand your logic with regards to using a short ground lead to the vehicle body rather than running the ground wire right to the battery's negative terminal.
i will lay out how i see it, and you can tell me where i might have misunderstood you or missed something somewhere.
so, you have your negative cable coming out of the back of your amp.
you need to get that cable connected to something that will complete the circuit.
the thing that completes the circuit is the negative terminal of the battery, not the chassis itself.
so, whether you connect a short ground wire to the chassis, or connect a long ground wire directly to the negative terminal of the battery, that negative cable coming out of the amp still has to get back to the negative terminal of the battery somehow.
to me, it seems like a much better idea to use a good, clean, properly gauged, copper wire to make that journey, rather than rely on old steel panels that have been bolted together, painted, sealed against leaks, possibly rusted, and were never designed or intended to be used as an RF ground, to make that same journey.
so why is it better to connect your ground cable to some arbitrary body panel, rather than using copper wire to make the connection to the negative terminal of the battery.
either way, the ground still travels the same distance from the amp to the battery.
please let me know your thoughts on this.
later,
__________________
  #10 (permalink)
Old 09-08-2008, 08:41 PM
Senior Member
Default
LC,
Yes the electrical ground is achieved but makes a longer trip for RF to get to ground.
RF and DC have different characteristics.
The longer ground acts as sort of a second antenna if you will and produces RF interference all over the vehicle.
This interference causes havoc on many things inside of the vehicle, from the Radio, to the windshield wipers, to the ecm, crank and cam shaft positioning sensor etc....
When dealing with RF you want the quickest low resistance path to ground. That is why when fully bonding a vehicle (grounding body to frame, frame to engine, alternator to engine, battery to frame) you use braided strap instead of round wire.
I agree that you should use good quality wire, I prefer 6 gauge or better. Also run the ground for the radio directly to the battery, just not the amp.
__________________
MoJo
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
